black smoke 50lbs back presure,cant accelerate,replaced most all sensors and pcm, still same problem, unhook intake air temp sensor problem goes away????
Its your exhaust back pressure valve. If its cold it most likley working properly. If ya want you can simply disconnect it. A two wire connector on the front- right side of the turbo base.
