Magnesol
Magnesol
We are currently using only 450 grams of Magnesol per 95 gallon batch which is well below the recommended percentages. Part of that can be explained by the 70 ml of glacial acetic acid (nearly 100% pure) that is added after the methanol exhaust and before putting in the Magnesol.
The above was cut and paced from this website. http://burlingtonbiodiesel.org/reactor_ii.htm
[QUOTE=willbd]We are currently using only 450 grams of Magnesol per 95 gallon batch which is well below the recommended percentages. Part of that can be explained by the 70 ml of glacial acetic acid (nearly 100% pure) that is added after the methanol exhaust and before putting in the Magnesol.
The above was cut and paced from this website. http://burlingtonbiodiesel.org/reactor_ii.htm[/QUOTE]
Thanks for the heads up Will, I'll plan on running some tests in the next week or two and see how it works................
FABMANDELUX.
FABMANDELUX.
Originally Posted by Cam_Man595
How much does Magnesol cost? And, can it be shipped?
I am working on becoming a west coast distributor, so the shipping will be less for those of us on the left-coast.
FABMANDELUX.
secondarychaos
Bio-diesel, Propane & Alternative Diesel Engine Fuels
08-01-2008 09:09 PM
superpony18
06-07-2007 05:17 PM
Phydeaux88
18
06-13-2006 08:20 PM
