Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 11-22-2006, 12:45 PM
Beerstalker's Avatar
Beerstalker Beerstalker is offline
Garage is empty, add now
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
1997 f-150 keyless entry
A couple of quick questions about the keyless entry system in a 1997 f-150.
My dad recently got the vehicle, it came with power locks but no keyless entry keyfobs. Is there an easy way to tell if the vehicle is equipped for keyless entry and we just weren't given the keyfobs?
If this vehicle does have keyless entry how can you program the keyfobs to work with it? I have two fobs and a stick on keypad from my 1999 f-250 SD that just got totalled and I would like to program them to work on this truck if possible. The manual for the truck says to take it to a service shop, but I know on my truck it was easy to program them by turning the ignition on and off a certain number of times and then using the keyfobs to lock the doors.
If anyone on here could help me out I would appreciate it.
  #2 (permalink)
Old 11-22-2006, 01:25 PM
amerimutt amerimutt is offline
amerimutt is starting off with a positive reputation.
Thats a good question! I'm dealing with the same thing. hopefuly someone could answer this for the both of us, but I can tell you when you do find out whether or not you have keyless entry, you can buy the fob on ebay and they come with programing instructions for about 20 or 25 bucks
  #3 (permalink)
Regta Regta is offline
Regta is starting off with a positive reputation.
I don't know how to tell if your truck was originally keyless equipped but here are the directions to program the remotes:
I copied it from another site.
To program the transmitters yourself:
1. Insert a key in the ignition and turn from 3(Off) to 4(On) eight times in rapid succession (within 10 seconds) with the eighth turn ending in the 4(On) position.
2. The doors will lock/unlock to confirm that programming mode has been entered.
3. Within 20 seconds, program a remote transmitter by pressing any button on a transmitter. The doors will lock/unlock to confirm that the remote transmitter has been programmed. (If more than 20 seconds pass before pressing a remote transmitter button, the programming mode will exit and the procedure will have to be repeated.)
4. Repeat the previous step to program additional remote transmitters. The doors will lock/unlock to confirm that each remote transmitter has been programmed.
5. When you have completed programming the remote transmitters, turn th ignition to 3(Off) or wait 20 seconds. Again the doors will lock/unlock to confirm programming has been completed.
  #4 (permalink)
Old 11-22-2006, 01:41 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
2002 Ford F-150
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
Does your key have the ring hole centered or offset in the black plastic? If it is offset, then your truck uses a coded key and likely has the keyless entry. If it is centered, keyless is likely not on the truck.
__________________
John, aka KingRanchMan02
`02 F-150 King Ranch SuperCab
Charcoal Blue/Arizona Biege, 5.4L 3.55 LS, 4x2, Diablosport Predator Programmer, K&N filter.
FTE Ride of The Week, 4/20/09 !!!
`08 Mercury Sable Premier, 3.5L Duratec, 6 speed auto
  #5 (permalink)
Old 11-22-2006, 02:08 PM
Hmmm off set Huh, Ok I have another later 01 escape to compare, the escapes is off set my 97 is not. But again a question, what if it's a duplicate key, although it does say ford on it
  #6 (permalink)
Old 11-22-2006, 02:59 PM
Regta, that was the process for programming them for my 1999 f-250, I tried it on the 1997 f-150 and it did not work. I have the paperwork from the keyless entry keypad that tells you how to program a bunch of different vehicles but it doesn't mention 1997 f-150s only 1998 and up.
Kingranchman, the keys have the long hole centered across the top of the key. I think the offset key like you are talking about is the PATS keys and I don't think they had them in the 150's in 97. I could be wrong though.
I was just wondering if I could look up under the dash for a certain brain box for it or something?
  #7 (permalink)
Old 11-22-2006, 04:46 PM
apowder97 apowder97 is offline
apowder97 is starting off with a positive reputation.
My key is centered and I do have factory Keyless. My truck is not equiped for coded keys.
  #8 (permalink)
Old 11-22-2006, 06:19 PM
By what your telling me, sounds like you need someone to tell you specifics on a 1997 truck. I have a 1999 and looked up those for mine
Good luck
  #9 (permalink)
Old 11-22-2006, 06:39 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
1997 used a different keyless system and required 5 cycles of the key rather than 8. If it has keyless then the door locks will cycle when you get to the 5th KeyON cycle within 10 seconds. It will also have a RAP module mounted under the dash against the firewall to the left side. They used different Keyless remotes as well. They are rather hard to find and more expensive than the later ones. Many of the early production F150 did not have keyless entry and just have relay driven power door locks.
__________________
My advice is just advice..Its free "IF THAT DONT FIX IT, SOMETHING ELSE WILL"
The most expensive tool in your box is "impatience"
IF IT AINT BROKE DONT FIX IT!!
My Missing Michelle
  #10 (permalink)
Old 11-22-2006, 06:47 PM
ncranchero's Avatar
ncranchero ncranchero is offline
1994 Ford F-150
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
steve.mckellop
Step 1 & 2 will tell you for sure if you have keyless entry or not.
A stick on keypad????? I thought they were hard wired and mounted in a hole cut in the door????????? I'd like to know more about these stick-on door keypads, was it factory?
If your fobs have the part # 2L3T-15K601-AA they will likely program to his truck. I posted a comprehensive listing of what vehicles this part number works on but I can't seem to search and find it, and I didn't save it on my pc.
__________________
Steve,
'94 F150 4x4 4.9L/5-speed/3.55(H9)
'02 Sport Trac 4x4 (lowered 2") FOR SALE
'10 TRANSIT Connect
  #11 (permalink)
Old 11-22-2006, 06:52 PM
The stick on Keypad is a dealer accessory item and will only work on 98 and up with the later Keyless entry.
__________________
My Missing Michelle
  #12 (permalink)
Old 11-22-2006, 07:04 PM
ncranchero's Avatar
1994 Ford F-150
steve.mckellop
Quote:
Mine IS a '98 ......... now I'll have to find one for mine!! Any Ford part numbers or eBay links by chance, anyone?
__________________
Steve,
'10 TRANSIT Connect
  #13 (permalink)
Old 11-22-2006, 07:07 PM
Just go to the Ford Parts Department and ask for that rediculously overpriced Keypad accessory.. LOL About 125.00 last I checked. Im sure if you hunt around Ebay you will find them cheaper. All it is, is a keyless remote that programs into your system just like your portable remotes, with a keypad and a 5 digit code to make it work.
Fair warning here too... once you stick it on and the adhesive cures, that badboy is ON! It will take a prybar to remove it!
__________________
My Missing Michelle
  #14 (permalink)
Old 11-22-2006, 07:12 PM
ncranchero's Avatar
1994 Ford F-150
steve.mckellop
I stand corrected. I DID find my list for the 2L3T fob and '97 F150's are not included.
THE list again:
Ford Truck Keyless Remote Fob Applications
2L3T-15K601-AA (2L3T15K601AA)
FCC ID : CWTWB1U331
CAN : 1788 104 575 (1788104575)
The 3 button (LOCK,UNLOCK AND HORN) keyless entry remote control will work with many different year and model Ford's, Lincoln's Mercury's and Mazda's Including:
• 1996-06 Ford Econoline Van E-150
• 2000-06 Ford Escape
• 2000-06 Ford Excursion
• 1998-05 Ford Explorer (2 Door)
• 1998-01 Ford Explorer (4 Door)
• 1998-06 F-150-, F-250, F-350
• 2005-06 Ford Freestyle
• 2004-06 Ford Freestar
• 1998-06 Ford Ranger
• 2000-05 Ford Sport Trac
• 1998-03 Ford Windstar
• 1998-02 Lincoln Navigator
• 1998-06 Mazda B2500, B3000, B4000
• 2001-06 Mazda Tribute
• 2005-06 Mercury Mariner
• 2004-06 Mercury Montero
• 1998-01 Mercury Mountaineer
__________________
Steve,
'10 TRANSIT Connect
  #15 (permalink)
Old 11-22-2006, 10:02 PM
Talking
Hey Homer glad your answering the question in general, this Rap module can you ID this more' color, marks, size color of the wires? elaborate some more pretty please. Thanks
Tags
15k601, 1997, 2002, 2l3t, 3l2z14a626aa, aa, entry, f150, f350, ford, keyless, lincoln, ls, module, part, program
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Fordฎ is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
