Canola Oil for Biodiesel...Better??
Canola varieties update...I guess
Hi Don...I read through the RR canola articles. Interesting! At this point we'll just have to see what develops...the seed is in the ground. One of the reason we grew the RR canola was to help clean up the cheat grass always present in our fields in the region. It will be very interesting to see if this RR canola manages to spread as it has in Canada. They have a lot more moisture up there than we do and grow their canola on dryland farms. We can't do that where we are, so that would reduce the chance of unwanted spread of seed. However, there are lots of circles all around the area. We'll just have to keep a close eye on it at this point.
I guess I find it interesting that considering the Canadian issues, the local seed companies were able to sell the RR canola. Do you have any info on that??
Also, a lot of this was going on around 6 years ago...any updates from Canada that are more recent??
I sent you an email...yesterday, I think...did you get it?? Sometimes my Hotmail emails get filtered out and people miss them.
Morning Becky, You need to rethink this RR canola thing. Summerfallow should REDUCE the amount of volunteer, because of tilling in the "off" years. Canadian experience shows just the opposite is true, canola seed can lay dormant for better than 6 years!
Water is not much of an issue with canola, this plant is basically a desert plant, and will produce MORE seeds when "stressed" with less water in the spring.
Growing RR Canola on circles does not allow time for summerfallow, so tilling the volunteer canola is not an option. The volunteer RR Canola MUST be removed with chemicals, which has been shone to be difficult, if not impossible............
As to why local seed companies promote RR Canola? Salesman will sell anything............
We've found that cheat grass is not much of a problem with canola stands that are well developed going into winter, the "leafy" canola shades the ground, and does not allow much weed growth.
I will look in my files and see if I have any newer info on the Canadian problem.
What variety of seed did you plant, and how many lbs per acre? Sorry I did not get your last email. You are in my address book, so my spam filter should not stop any incoming emails.
FABMANDELUX.
FABMANDELUX.
Yea...but rethinking is really not an option at this point, since the seed is already in the ground. We'll have to see what happens at this point and do what we can to control accidental spread. I guess I'm wondering how the local seed guys were "allowed" to bring this seed in, if the problems have not been solved in Canada. But, like you said, if there's money to be made, they'll try to make it. Bush admin hasn't been too interested in environmental concerns...maybe things got too relaxed on this issue.
We don't worry about the cheat in the canola fields...we worry about it in the bluegrass fields planted after canola.
FABMANDELUX.
Let's continue with further discussion about canola and biodiesel.
Fab...you said we should be able to make our own BD for around 50 cents/gal.. Does that include crushing?? Do you crush your own??
Oh...and I learned the other day that we actually have 1 1/2 circles uncontacted...only contracted 1/2 circle. So we're talking about 700,000-900,000 lbs of open market seed...how much oil will that produce? Anyone interested in buying some fresh canola seed to crush next summer??
Offroad fuel is selling here for $2.67 / gallon now, that means your 43,295 gallons is worth.........$115,597.65 + 252 tons of feedmeal @ $140 = $77,616.
This yealds a grand total of $193,213! The partys at your place!!!
Crushing costs is the lowest part of making biodiesel. We don't have our crusher yet, won't be here untill spring. We bought a small unit for testing, it will crush aprox 2,000 lbs of oil per day, and cost about $1,000.
I have 2 customers that would probably buy all of your seed if you wish to sell it, BUT WHY!!!I don't know how much diesel you buy each year, but why not make your own!
If you have a good fabricator/ mechanic on the farm, you could build your own system for very little cash out of pocket, and be "off-grid" as far as fuel goes.
The 500 gallon / day plant I designed for Bill Riley/USDA would easily do 50,000 gallons/year, and should cost around $50,000 or less even if you had someone else build it..............We should talk!
FABMANDELUX.
SOUNDS SO GOOD!!! I'll have to dig into our records and see how much diesel we buy each year.
We'll sell the extra canola to the highest bidder...of course. We have semis for transporting to a buyer in the Washington/Oregon area at harvest. Our contracted portion is for 13cents/lb, so we're hoping for a little more on the open market.
I emailed Bill Riley...we're signed up and will be at the demo in Moses Lake Dec. 11th. Real anxious to meet you!!
What would a sizable crusher cost?? We can build just about anything else we would need most likely. Would be a good winter project. Lots and lots and LOTS of junk out back that we could probably use. Wer'e the "never throw anything away" types. Same farm for 4 generations...you can imagine all the junk.
I'll pass your numbers on to the group and see what kind of reaction I get. I'd be right on top of this if it were just me making the decisions.
Who do you sell your meal to?? Dairies?? Feedlots?? Both?? Do hogs like canola meal?? Chickens?? We've got a large chicken ranch nearby and a small hog farm, too.
More numbers...
Fab...I took your numbers and worked up a spreadsheet. What fun!! Showed it to my husband and he's cranking the brain cells. We really need to find out how much the BD will cost us to make in equipment, labor, transport and processing supplies. Do you have any numbers for those??
Also, the equivalent value of our canola seed per lb. goes from 13 cents to 18 cents per pound, if we turned the seed into BD and feedmeal. But, that doesn't include the processing costs. We need to see those to honestly evaluate all this.
Oh...and are there some alternative fuel tax credits for users and not just producers??
I also spent the time digging through our diesel records. We use around 12,000 gal. diesel/year. We'd be able to produce over twice as much BD from our open market canola.
And one other thought...what about any taxes the state or feds might want to charge us for using homemade BD on highways?? Know anything about that??
Oh so many questions!! Thanks!!
What would a sizable crusher cost?? We can build just about anything else we would need most likely. Would be a good winter project. Lots and lots and LOTS of junk out back that we could probably use. Were the "never throw anything away" types. Same farm for 4 generations...you can imagine all the junk.
How much oil do you want to crush? The model we ordered will do 2,000 pounds/ day or about 120 gallons / day COMPLETELY UNATENDED. That's 3,600 gallons per month or 43,200 gallons per year. One nice thing about doing this on farms is the fact that you can store the seed and crush for oil as needed. This eliminates the need for a tank farm.
"crushers" range from $1,000 to $150,000, but we're not talking about 30,000,000 gallons a year here!
Can't wait to prowl your bone-yard And there "treasures" never junk!
Canola meal is about 40 percent protean, and works great for all livestock. I have two University studies, both have shone the ability for mixing 10 percent[by weight] of the glycerol byproduct with livestock feeds. One study is for cattle, and the other is for chickens! If you would like them just let me know and I'll send them[there Pdfs].
FABMANDELUX.
#29
Where do I start? Your making this old brain work to hard
You need to change the way your thinking about this. We as farmers need to do what we do best.........Grow things! Competing with large commercial biodiesel plants will not work! Selling fuel to the public, adds large amounts of $$$$ and huge amounts of BS to the process of farming. My whole focus is to remove the energy dependence of the family farm.
Making the fuel we need will change the way we farm. Off road fuel is exempt from most government interference! You do not have to register your fuel with the EPA, and you don't have to join the NBB [and send them $$$]. The amount of fuel you use for on-road is kept in a separate tank and you send the State their $.24, and the Feds their $.23 for every gallon used. Simple!
You said you use about 12,000 gallons/ year? The "stuff" you need to make that amount of fuel is most likely already in your bone-yard! It was in mine!
Sell what you don't need for the farm on the open market, there is a very strong demand for this seed crop in the northwest and it will continue to grow, BUT CONTROL YOUR OWN FUEL!
Want to do more??? Form a Co-Op with other local farms, even with those that can't grow canola, and every member can purchase off-road fuel for farming without Gov interference!
I'll send you my phone # by reg email, Please call me and we can discuss this in more detail.
FABMANDELUX.
FABMANDELUX.
#30
Yes indeedy...that's what I'm talking about. I want to know what a crusher would cost to make just what we need for the farm. I'm not interested in producing fuel to sell to the public...others will be doing that.
But, as you said, why not make our own since we will have the canola and "junk" to put something together realitively inexpensively. It would appear to me that our biggest expense to make our own will be the crusher...that's why I'm asking for a price estimate on that. I suppose I could seach the net myself, but you seem to have a lot of the info in your head .
We can visit at the Moses Lake meeting about all this in a couple of weeks. That will give us some time to work up lots of specific questions.
AND...if the demo in Moses doesn't last too long, we could take you by our bone pile to see what we have that we could use. If you go home through the Tri-Cities, we'd be right on the way. Or, not too far off the path south.
AND...if we take our discussion about this off the forum we'll get yelled at again!!!
