4 x 4 conversion question
One more try - my last reply wouldn't take for some reason.
If you do a search for "Ultimate SAS project source" you will find a lot of info for Dana 44/60 swaps with either coil or leaf springs. Most of those projects have custom built spring perches, and a lot of them end up being low enough to cause front driveshaft pinion angle problems.
Also, like 96P said, you may end up with two different wheel types if you are not careful. I don't know when Ford switched from lug-centric to hub-centric wheels, but Ido know that my 97 is hub centric.
Good luck and keep us posted, I am interested in the same project.
