2003 F150 Fuel Filter - Ford Truck Enthusiasts Forums
Old 11-21-2006, 01:22 PM
lkey32 lkey32 is offline
lkey32 is starting off with a positive reputation.
I don't normally work on my truck, but I am wanting to change the fuel filter. I have a 2003 F150, 4.6L. Where is the fuel filter located in relation to the engine? How easy is it to change it myself?
Old 11-21-2006, 01:34 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
It is on the inside of the frame more or less under the drivers door. You also need a special fuel line tool to release the clamps. Get the metal one from NAPA it works better than the plastic ones. They can be hard to get off and you may need to spray WD-40 in the fitting and spin the tool in it a bit to get the filter to come off.
Old 11-21-2006, 06:22 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
welcome to the FORD forum Ikey. If you dont know what your doing, changing th efilter can take a couple hours the first time. I would buy it at Aoto Zone or other auto store and talk to the counter guy for a few minutes. This is not a screw driver and hose clamp job. THE new filters have 30-50 psi pressure inside and the fittings are a push on compression fitting. You do need a special "tool" to get it to come loose. They can be difficult to get apart.
Old 11-21-2006, 06:41 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
You will also need to bleed off the pressure in the system before removing the lines or you will have fuel spray everywhere!!!
Old 11-21-2006, 10:13 PM
forgot about the pressure, easiest way is to remove the fuel pump fuse and crank the engine over a few times. You will still get fuel on you but the pressure should be relieved.
Old 11-22-2006, 07:49 PM
JH6 JH6 is offline
JH6 is new and has a neutral reputation at this point.
I just pull the filter off.
Just watch your eyes, gas won't kill you.
6.0 no start after fuel filter change pjohn192 6.0L Power Stroke Diesel 41 08-26-2016 12:28 PM
fuel filters? bobkonaben 1999 to 2016 Super Duty 1 04-11-2015 06:43 PM
2003 fuel filter blackestate Expedition & Navigator 12 05-06-2014 10:23 AM
2003 6.0 Rough Idle Jnas860 6.0L Power Stroke Diesel 15 10-28-2011 09:36 PM
2003 Expedition fuel filter location? 2XExpy Expedition & Navigator 1 07-22-2004 02:28 PM
Tags
03, 2003, change, changing, f150, filter, fiter, fitler, ford, fuel, location, removing, replacement, replacing, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
