You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I was doing some modification work on the fuel lines of my truck last weekend and took a "biodiesel shower"...basically got my arms soaked with 5% biodiesel. I burned the old shirt I had on when I finished the job and took a long hot shower. Now I have been around diesel fuel all my life and have gotten it on me a number of times, but this is the first time I actually got biodiesel on me. Starting almost immediately after getting my arms wet, an allergic reaction began. I have red welts and it itches like poison oak or poison ivy. I was wondering if anyone else has experienced this and do you think the allergic reaction is to the 5% bio or the 95% diesel. I know I could go expose myself to pure diesel and find out, but that experiment does not enthuse me much at this time.
Commercial bio or you made it? If you bought it there's no telling what it was made from.....Do you have allergies normally?
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
New one on me, I've been using B-100 for 3 years, and have never had that happen.........I've been soaked in it, We use it in our solvent tank, with 5 different people using it, and have never experienced anything like what you are describing.
FABMANDELUX.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
I have never had an allergy to anything before this event. I did not make the biodiesel, bought it at local supplier. I think over the years I have been exposed to numerous solvents (PERC, trichlor, toulene, etc, etc) and I have just become sensitized enough to be affected. I just applied some cortisone cream on my arms and it has been of some relief. After this is over I may try my pure diesel exposure and see what happens.
niemerise
If you still have some of that BD blend around and can get some litmus paper test it (try both ways acid and base it will take two types of litmus). Its possible that the supplier did not neutralize the BD and you got a chemical burn. Depending on the method used to convert the VO to BD it could be either acid or base.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
I have a tankful (40 gallons) of it...when I go to town I will pick up the litmus paper, if I can find some. What is the normal range of pH for biodiesel?
For the most part it should be neutral, around 7, but if traces of the chemicals used to accomplish the trans-esterification (convert VO into BD) remain could be decidedly basic, over 7, or acidic, under 7. you should be ok with a range of 6.5 to 7.5.
I bet Fab knows what ph his ready to use BD is at. Maybe he will chime in here.
If it does turn out to be a case of residual chemicals I would consider changing suppliers because you could damage parts in the fuel system. This is the biggest source of problems among DIY BD makers.
BTW your atavar sure looks like Kinky Friedman, a candidate for Gov of TX in the last election.
__________________
6.2 to 6.7 I've found that "dry-washing" with Magnesol removes the base catalyst very well. Most home brewers that use the water wash system find they have to add a mild acid [like vinegar] to neutralize the biodiesel. This is just adding MORE water to it, and we all know what I think about water-washing.....................
FABMANDELUX.
__________________
