Towing 1 Ton Ford Van
Newbee here: Got a 95 7.5L 1 ton 15 passenger van
Got a 94 7.3L 1 ton 15 passenger van;I often pull a 4 ton 16' trailer with a van on board. Done this several times, the 4 ton seems OK but I have a 6 ton 20' trailer that I never have used; do not know if these vans will pull it. I see regular F350 Pickups pulling 6 ton or greater (the trailers look bigger than my 16'). Both vans have the E40D trans; does the F350 & the 1 ton van have the same trans? Could I pull the 6 ton with no trouble to the trans?
Thanks Tater
Not to be too much of a hard case, but....
1) Read the owner's manual - 12K has got to exceed the official towing capacity.
2) "Can it tow" doesn't explain whether you live in the mountains or on flat land, or whether you're towing it 15 miles or 700 miles.
3) Transmission cooling would be critical. I suspect your transmission would run VERY hot with that towing load.
4) Braking/emergency maneuvers could be scary.
5) You need an F350 with a gooseneck trailer if you're going to regularly tow 12K lbs.
Legality and sanity aside:
The trannies are probably the same. The gasser E4OD might have a lighter-duty component or two inside. That said, the E-series is notorious for not cooling as much as the F-series. It's one of the reasons, I believe, that the 7.3 diesel (and the 6.0) in the E-series are de-rated (less power) than the F-series. To keep the heat down. (intake/exhaust are also to blame, but that's another subject)
So, I wouldn't expect it to last as long as the exact same tranny in an F-series.
Thanks
Thanks for the replies. I went to the Ford Dealer today to check on towing. The 7.3 has a 9300 GVW & the 7.5 has a 9100 GVW. The Ford service tech said that he was not sure on that old of a model what it could pull. He did say that the GVW was for the van, trailer & whatever was loaded on it. I took the van to the recycle scales & it weighed in at 6440 lbs; a 6 ton trailer weighs 2200 lbs, so that means I can only haul about 660 lbs. I thought GVW was the trailer plus the load; is the service tech wrong, cause I have pulled a 4 ton w/another van on it (that combo would be about 4 ton+)?
Thanks Tater
Thanks Tater
motomax55
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
08-03-2015 03:25 PM
geoffhazel
03-15-2015 04:36 PM
baddad457
22
10-10-2014 06:51 PM
Glen-E350
20
10-11-2013 05:43 PM
muscletruck7379
01-22-2007 07:11 PM
