Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero and 1961 - 1967 Econoline
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-20-2006, 09:09 PM
terry j is starting off with a positive reputation.
data plate??
I am in need of data plate deciphering. Two 1965 Econolines 1 van 1 pu.
Van Plate reads:E14JH589981 (2nd Line) 090 M E140 D89 4A 04 (3rd line) 3600 129 4000 72
P/U Plate: E10TH701160 (2nd line) 090 3 E100 D87 A 031 (3rd line) 3600 85 3800 73
Basically I understand WBase 090inches GVW 3600, HP 85/129 ,RPM3800/4000 The rest remains a mystery. Tried to figure these out through Jim Bares other answers to same questions but admit I'm lost. Pickup is 5 window chrome bumpers and spears w/stainless ,poppy red and a blast to drive. Van is a parts piece with padded dash ,automatic trans, slide out side step and 1 extra knob on dash where the lighter should be. Lighter is next to heater controls.
Thanks for any help you might pass on. Great site great rigs.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-21-2006, 12:54 AM
j-md's Avatar
j-md is starting off with a positive reputation.
E14 = Econoline Regular van
J= 240 Cubic Inch Engine
H=Lorain Ohio Assembly Plant
589981 = Assembly Sequence Van Born in September of 64
090= 90" Wheel Base
M = Winbledon White Colour Code
E140= Van 3600 GVW
D=CUSTOM CAB INTERIOR SOFT TRIM PREFIX, BEIGE VINYL AND WOVEN FABRIC?
89= NOT SURE?
4A = Light Duty 3 speed manual
04 = 3.50:1 2780 lb capacity 9" Rear End
3600= Mav GVW
129 = Certified Horsepower
4000= Max RPM
72= San Jose Sales District
  #3 (permalink)
Old 11-21-2006, 12:54 PM
66gpw's Avatar
66gpw is gaining momentum as a positive member of FTE.
The pickup I will give a try here. I have a shop manuel from that year.
E10 Reg. pick up
T 170 6 cyl.
H Lorain Plant
Remaining #'s say it was manufactured in June of 65
090 is 90in wheel base
3 is suppose to be a letter for color.
E100 Regular pick up
D87 I think that is suppose to be a B87 which is a custom pick up.
A C-4 Automatic
03 Axle ratio. of 4.11
3600 gross vehicle weight
85 Horse power
3800 RPM
73 Salt Lake City Sales District.
  #4 (permalink)
Old 11-21-2006, 07:40 PM
Jimbare's Avatar
all alone in the world
Jimbare is gaining momentum as a positive member of FTE.
fed the numbers into my super secret decoder ring, will get back to you in a while!
j-md and 66gpw look real close, prolly got it spot on!
__________________
jim
underated and overworked.
  #5 (permalink)
Old 11-21-2006, 09:12 PM
Definately helps a bunch. Transmissions seem inverted though. P/U is a 3spd ,van is an auto. I may have swapped numbers/alpha. Glad to know there is a 9" in the mix. Wasn't sure about the 7.25. Never really noted that diff. Thanks to all!!
  #6 (permalink)
Old 11-21-2006, 10:01 PM
j-md's Avatar
I get for the p/u
A=3 Speed manual
  #7 (permalink)
Old 11-21-2006, 10:05 PM
j-md's Avatar
If it's a B paint code ...Caribbean Turquoise 556
That's all I know ... jim help out the newbies!!!???
J-M BC
  #8 (permalink)
Old 11-22-2006, 06:13 PM
the 3 denotes Mustang poppy red. That would go with the spring special. 251.00of free options!!! Have the flier from Ford dealer that explains what this was about. Included chrome bumpers,falcon hubcaps,chrome and stainless side spears.poppy red or wimbeldon white paint. And for 4.00 more mustang lower body stripes from 3m.
  #9 (permalink)
Old 11-22-2006, 10:10 PM
Jimbare's Avatar
j-md was correct on his decode! one thing tho, the extra letter on the trans code and some of the eqipment means the van is probably a travel wagon or other conversion.
the pickup IS a spring special! should either have side trim or the holes where it used to be. heres the decode for it.
E10 = Econoline pickup
T = 170 engine
H = Lorain Ohio assembly plant
701160 = June 1965 serial number (1965 model)
090 = wheelbase
3 = Poppy Red paint
E100 = 1/2 ton pickup model
D = beige custom interior (custom equipment
package)
87 = pickup body style
A = 3 speed transmission
031 = 3.50:1 light duty axle
3600 = 1/2 ton GVW
85 at 3800 = certified net HP at RPM
73 = Salt Lake City sales district
__________________
jim
  #10 (permalink)
Old 11-23-2006, 09:06 AM
BIIman is starting off with a positive reputation.
This and other things you'll want to know will compel yopu to buy the Econoline Manual available at Mac's Auto real reasonable-$31.00 delivered.First page is the plate code, the rest is real detailed.
  #11 (permalink)
Old 11-23-2006, 11:38 PM
thanks to all. Your right the manual will be a help. Did some Xmas shopping today and that was first on the list. The van will be a donor for a number of items. Mostly sheetmetal. The floors haven"t even been scratched and the rest is virtually rust free. I"ve located another "spring special" that needs Mechanics. So mine will be given an update to the drivetrain and interior. The other will be a stock piece. By the way the extra knob on the dash turned out to be 4-way flashers.
  #12 (permalink)
Old 11-24-2006, 12:14 AM
j-md's Avatar
terry don't buy a new manual ... they are a quite reasonably priced on e-bay. i have a '65-'66 and '67 manuals for less than 50 usd including shipping
They have saved me thousands in aggravation alone ...
J-M BC
  #13 (permalink)
Old 11-25-2006, 11:21 AM
J-M ,allready ordered from MAC's. 31.00 w/discount seemed reasonable. It will be the second FORD manual in my BowTie garage.
  #14 (permalink)
Old 11-25-2006, 11:36 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.
On passenger cars VIN...
...A "T" engine is a 200 Six
Should be the same for Econolines.
This is from memory...but I believe it's correct.
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
