Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Audio & Video Systems, Navigation, Satellite Radio and Mobile Electronics
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-20-2006, 03:49 PM
JustinRoyce is starting off with a positive reputation.
Exclamation 95' ford bronco troubles
I just installed a new head unit in my bronco but for some reason the max volume is very low. I also installed new speakers in the doors. The problem still did not fix. I was just wondering if anyone could help me out with this. & one other thing, does the 95' broncos come with a stock amp already installed in them?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-20-2006, 07:19 PM
scbronco is starting off with a positive reputation.
hey justinroyce
did you have to wiring in the head unit or was it a direct harness plug in. are your speaker wires switched meaning is the negative on the positive and the positive on the negative.
  #3 (permalink)
Old 11-20-2006, 07:35 PM
Question
I ordered the head unit off line and it came with a wiring harness that just plugged into the stock harness. I might have to check to see if maby i connected the wrong wires but im pretty sure i didnt. If i were to accedenly have done that, is it possible that it would do that to the sound?
  #4 (permalink)
Old 11-20-2006, 07:39 PM
yeah well its only one way to hook the harness up.. what kind of headunit is it.
yes hooking the speakers up the wrong way can affect the sound becuase of the different ways to wire up speakers. normally when you add more you add it in a parellel curcuit which is what the truck is so just make sure there on the right ones
  #5 (permalink)
Old 11-20-2006, 08:01 PM
its a clarion head unit and the speakers are good cuz i was switching the wires around to see if it sounded different and it still sounds the same. so i dont even know what to do
ima go check the head wires right now n see if i cant find an error
thanks though
  #6 (permalink)
Old 11-20-2006, 08:37 PM
clarions good im surprise i dont know what it could be....
  #7 (permalink)
Old 11-26-2006, 02:10 AM
chrono4's Avatar
chrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to all
How low is really low? Whats the wattage output of the headunit?
__________________
--Andrew--
Rocking a 79' f150 with a 300 and a 4 speed........
Full York OBA Install
Welding a 9"
Very simple front bumper
Lowering Spring Towers
Hi, I'm Andrew and I have a wheelin problem that is often disrupted by fabbin and drinkin, glad to meet yall.
Technical Advisor
  #8 (permalink)
Old 11-26-2006, 02:19 PM
ReAX's Avatar
Molon Labe
ReAX is gaining momentum as a positive member of FTE.ReAX is gaining momentum as a positive member of FTE.
What does the headunit produce versus what do the speakers need in watts? If you have speakers that require more than 25watts, you wil most likely need to add an amp.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
