how many O2 sensors on my 96 Ranger- 2.3L? 2wd - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-20-2006, 02:50 PM
MossyOak23l MossyOak23l is offline
MossyOak23l is starting off with a positive reputation.
I am getting codes P0136 and P0141, both for bank 1, sensor 2. The previous owner had a local garage install a new catty, and all new pipe from therein back. It was a PA truck, so It didn't need properly working emissions controls to pass inspection. I just replaced the front O2 sensor, and am still getting codes, but for sensor 2. Does this mean that there should be a 2nd o2 sensor somewhere behind the catty?
Old 11-20-2006, 07:04 PM
alaska mike alaska mike is offline
alaska mike is starting off with a positive reputation.
2 02 sensors
yes there is 2 o2 sensors one in front of cat one in back of cat .my 96 2.3 96 ranger has two .has your fuel mileage gone down hill real fast.
Old 11-20-2006, 07:38 PM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
sensor 2 would be the one after the cat, but that does not usually depreciate the fuel mileage, it is there to monitor the proficiency of the cat.
Old 11-21-2006, 01:40 AM
fuel mileage is bad
i am only getting about 310 miles to a full tank and should be getting around 400 miles
Old 11-21-2006, 07:07 PM
bad o2
the check engine light came on in my 96 ranger splash 2.3 .
i took the truck to auto zone.they checked the computer .it said that the front o2 was bad.bought new one.mileage came back to normal .aboit 22.my truck has over 189000.still runs good.unhook the positive cable from your battery for about 2 minutes it should clear the bad code.
Old 11-24-2006, 07:47 PM
MazdaRangerGuyInSTL MazdaRangerGuyInSTL is offline
MazdaRangerGuyInSTL is starting off with a positive reputation.
There are two sensors total... one oxygen sensor between the cat and the engine (Bank 1, Sensor 1) and one behind the converter (Bank 1 Sensor 2)... I'm wondering if they installed a "generic" cat that didn't have a threaded hole for the rear sensor... so instead just left it unplugged...?
Old 11-25-2006, 10:08 AM
Bart99GT Bart99GT is offline
Bart99GT is starting off with a positive reputation.
As mentioned already, the second O2 sensor doesn't do anything for fuel mixture. Its there purely to monitor the efficiency of the catalytic converter. Since I don't like replacing parts that don't directly effect the functionality or safety of the vehicle, do a search for "CEL eliminator". For less than $5 in parts, you can rig up something that fools the computer into thinking that the rear O2 sensor is present and functioning properly. Better than spending $40+ to replace a O2 sensor that doesn't do squat to insure the engine runs well. It also comes in handy should you remove the catalytic converter entirely.
The converters on Rangers don't have a O2 sensor bung in them, BTW. The 2nd sensor threads into the pipe a few inches after the converter.
Old 04-09-2014, 08:52 PM
Ivan40oz Ivan40oz is offline
Ivan40oz is starting off with a positive reputation.
Check engine light turned on!
Quote:
It burns gas quick and engine light turned on. The truck turnes on but then turn off followed by a rough bug out shaking noise.
o2 sensor, upstream 2011KingR 2007 - 2014 Expedition & Navigator 3 10-18-2016 01:10 PM
Please Help with O2 sensor problem. wiwillis1980 Explorer, Sport Trac, Mountaineer & Aviator 14 06-25-2014 12:02 AM
03 Expedition: Codes P2195, P2197 and P0171 MCGA Expedition & Navigator 10 07-23-2012 11:21 PM
2005 2.3L Escape Problems... GRNMSTR Escape & Escape Hybrid 1 11-03-2011 06:27 AM
o2 sensor??? 88PONY 1987 - 1996 F150 & Larger F-Series Trucks 8 10-23-2009 09:44 AM
Tags
23, 96, catalytic, code, converter, ford, have, number, o2, oxygen, p0136, p0141, ranger, sensor, sensors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
