65 352 exhaust manifolds
I need to remove the exhaust manifolds to change the gaskets. Im having trouble removing them. I have soaked with pb blaster and also heated up the manifold with no luck. I have broke one already and dont feel like breaking more. any ideas to getting them off. Thanks...
Keep breaking them and deal with it. The top ones almost always break as the heat has gotten to them and they stretch when moved at all. Right angle drill might be the only solution to the issue, unless you get lucky and have something to grab with a pipe wrench. I used longer grade 8 bolts when replacing so the end passes the top of the ear. Keeps moister out. If it will help in the long run is yet to be seen.
Once you get them off, as mine seemed to easily fall off, don't put them back on with a gasket. Ford FE engines came from the factory without gaskets. Simply make sure the seating area on the exhaust manifolds are planed smooth and level. Some maybe pitted which will mean another manifold. That is what I did with mine then put them on with a little copper silicon sealer. Mine have been fine ever since without any exhaust leaks compared to when gaskets were used.
Thanks for the help. I might just have to take them out and the ones that break drill out. I plan on replacing all the bolts. There are no gaskets on them know and I thought that was why they were leeking. The out sides are pitted and rusted. I might have to replace the manifolds or by headers. does anyone know of a good header thats not to expensive...
Originally Posted by jowilker
Say What??? Was this on 77 and later engines??
John
John
What I did was, like has been mentioned before...heat engine up and soak the heck out of them...PB blaster and nearly every thing else...did that quite a bit over the course of a couple weeks...then I took it to the shop and had them do it...no broken bolts and no broken ears...
My logic in it was if they broke while they were working on it...its their nickel to replace parts...i.e. heads if an ear broke...
No gaskets were used as was said above originally....
CS65
CS65
another suggestion is if you can reach it with a hammer hit the bolt head a good lick. it breaks the rust bond in the threads. if the engine is in the pickup most of them will not be accesible to do this. learned that from an old mechanic and have done it numorous times and it works abot 80% of the time. also i would recomend using high performance gaskets as they are a little thicker and may save you have to have the manifold shaved. also use a antisieze thread lubricant going back together. makes future work on it much easier.
