Rear End Selection
Rear End Selection
Hi all
I am in the process of identifying what rear end to get for my 56 F100.
Here is my question. What is the effect of the rear end not tracking directly behind the front tires?
My 56 is a flat bed so I have no fenders to fit up to. There are a lot of rear ends that are not the same width as mine. I can even put a dually on it. But I don't want to introduce bad handling into the truck
Rear End Selection
I had the box off mine, when I installed the 9" axle. Just center the axle on the frame with both sides (wheels/tires/brakes) sticking out the same amount. I measured from the rear of both frame rails to make sure the axle was aligned 90 degrees to the frame axis. The last step was to weld the spring perches and set the rear pinion angle.
Rear End Selection
[updated:LAST EDITED ON 12-Jun-02 AT 10:35 AM (EST)]Thats great information. Thanks
But what (if anything) happens if you use a rear end that is not the same width as the original. If I track 1 or 2 inches outside of the original will it cause any problems with drivability?
