Engine swap for a 1998 F-150 4.2L to a 5.0L - Ford Truck Enthusiasts Forums
Old 11-19-2006, 01:21 PM
rickywoff rickywoff is offline
rickywoff is starting off with a positive reputation.
Lightbulb Engine swap for a 1998 F-150 4.2L to a 5.0L
I've been wanting to do a engine swap for a while to get a some more rumble out of my f-150. I've got a 1986 lincoln (futher derby car) with a fuel injected 5.0L in it that i've thought about putting in my f-150. Anybody have any suggestions?
Old 11-19-2006, 02:57 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Mine would be don't bother, you can put a stock PI 5.4L in very easy compared to the 5.0L and it will have 260hp, the 5.0L stock won't have anything near that. With all the bolt on's you can think of you could push 300hp fairly easy with the 5.4L then stick a 50 shot of nitrous on it for a cheap performance fix.
For all the time and money a 5.0L would take you could tear into a 5.4L or even 4.6L and should be able to push 350hp N/A out of them with reworked heads and intake etc etc. Or you could just drop $4K on a low psi blower and be at 350hp easily.
Old 11-19-2006, 05:09 PM
preppypyro's Avatar
preppypyro preppypyro is offline
Posting Legend
preppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud of
Maybe he isnt going for lots of horsepower. Sounds like he has a motor sitting around that could be used instead of maybe spending so much cash on getting a 5.4! Keep in mind if you get a 5.4 you still have to buy a ton more stuff to get it to work in that truck, wiring computer etc.
Old 11-19-2006, 06:14 PM
It would be far cheaper to get the 5.4L to work than a 5.0L. Aside from a ECU reflash the 5.4L is more or less a bolt in, as close to one as you can get these days. You could run it off all the 4.6L wiring. It would be easier to go to a NPI because of some sensors the PI would have but really nothing major compared to trying to get a 302 to work.
Old 11-19-2006, 08:46 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
the boy took a 4.2 out of an F150 and installed a 302. They used a distributor and carburetor to keep it simple. Had to make eneing mounts, etc. Biggest problem they had was it vibrated BAD when they got done. I did a little research and found the 4.2 is a balanced motor. The 302 he had was externally balanced with the flywheel and harmonic balancer. I had to pull the motor and remove the flywheel, machine it to match othe old counterweight flywheel and reassemble. Dont remember the full story, but the starter hole was too far over to use the 302 flywheel and they had to get one to bolt to the 302, aht would accept the 4.2 motors transmission and clutch, etc. LOTS OF WORK, but runs o.k. for past 6 months.
Old 11-19-2006, 09:51 PM
I got 4.6L in my head, forgot he had a 4.2L, there are some nice 4.2L turbo set-ups out there as well.
Old 11-19-2006, 09:58 PM
I've got all the sensors and everything else to convert over to the 5.0L, I was wondering about the transmission and the flywheel fitting right.
Old 11-19-2006, 10:02 PM
The lincoln is still road worthy except for a power steering leak.
Old 11-20-2006, 10:48 AM
ggarrahan ggarrahan is offline
ggarrahan is starting off with a positive reputation.
What are the emissions laws in Tennessee? Here in California the swap you mentioned would not be legal for street use, as it would not pass our smog inspections.
Old 11-20-2006, 08:17 PM
They never have checked the emissions on any of the vehicles that I have ever owned before.
Old 11-20-2006, 09:48 PM
Dustin1690 Dustin1690 is offline
Dustin1690 is gaining momentum as a positive member of FTE.Dustin1690 is gaining momentum as a positive member of FTE.
Yeah in my own opinion just buy another truck with at least the 4.6 or 5.4 and save the time money and headache just my 2 cents engine swaps in newer vehicles can be done but much more complicated cause of computer etc thats the easy way out unless you would really want to swap it
Old 11-21-2006, 06:07 PM
grandmastaj's Avatar
grandmastaj grandmastaj is offline
grandmastaj is starting off with a positive reputation.
Quote:
They only test in the metro areas like Nashville and Chattanooga. If he lives in a rural area he won't be tested.
96 f150 5.0l motor swap myboysnme General Automotive Discussion 1 01-10-2016 11:31 PM
Engine Swap Questions williameub 1987 - 1996 F150 & Larger F-Series Trucks 4 09-14-2013 06:05 PM
5.8L swap in 5.0L F150 onthefloor4x4 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 20 04-07-2011 10:43 AM
Auto to manual tranny swap - '92 f-150 302, V8 RWD breno1987 1987 - 1996 F150 & Larger F-Series Trucks 2 09-22-2010 01:06 AM
5.0L vs 5.8L (302 vs 351) Blue2 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 14 07-08-2004 02:29 PM
Tags
15042, 1993, 1997, 1998, 42, 42l, 50, 50l, conversion, engine, f150, ford, heritage, motor, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
