Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-19-2006, 11:02 AM
Mo52Merc Mo52Merc is offline
Garage is empty, add now
Mo52Merc is starting off with a positive reputation.
Flathead Six models
I'm just curious what models the flathead six came from the factory in. I spotted a 1.5 ton on ebay with a six and was just curious if the little 223? was in it or if it would have the 254. Just doesn't seem that the smaller would be in a truck that size.
  #2 (permalink)
Old 11-19-2006, 03:37 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
According to the shop manual - I'll look for more info in my operator's manual - the 254 was only used in the F6 conventional and cab-over.
F6 was rated as a two ton. 1 1/2 ton would have been an F5, so it should have been a 226.
  #3 (permalink)
Old 11-19-2006, 10:52 PM
Ok thanks.
  #4 (permalink)
Old 11-28-2006, 03:33 PM
51ford fan's Avatar
51ford fan 51ford fan is offline
51ford fan is starting off with a positive reputation.
There are cast numbers on the head, and also on the block at the pan rail just below and behind the generator. If it says something like 7HA, or OHA it's a 226 cubic inch Flathead. If it's the 254 the numbers will be 8mth on both the head and block. I searched for 3 years to find the elusive 254. I finally found one, and upon tearing it down I discovered it had a broken piston and had put a hole through the cylinder. So maybe I can recoup my investment selling the internal parts.
__________________
Rod 51 F1 Truck
Flathead 6 / 3.23 Rear
S-10 5-Speed
"Keep on Truckin"
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
