Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-16-2006, 02:32 AM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
1993 Ford F-250
Sycostang67 has a good reputation on FTE.Sycostang67 has a good reputation on FTE.Sycostang67 has a good reputation on FTE.
Post Fitch Fuel Catalyst.
I keep seeing these adds for this Fitch Fuel Catalyst. It looks like you install it as if it were a fuel filter. I checked out the website, but I still don't know what to think. Is anyone here using one, or heard anything about them?
Here's the link.
http://www.fitchfuelcatalyst.com/pro...uto/index.html
__________________
http://www.ford-trucks.com/user_gallery/tmp/159/159207.520.390
1993 F-250 HD XLT Lariat SC 4X4 7.3/5spd ATS WG turbo @ 12psi, 3" DP 4" straight exhaust, 5" stacks, Hypermax cowl induction, IP up 3 flats, DPS stage 1 injectors, GPR LED mod, Pyro/Boost guages-186whp 363wtq @ 10psi
1986 F-250HD XLT Lariat 4X4 6.9/T19, soup bowl mod, straight pipe.
  #2 (permalink)
Old 11-19-2006, 09:01 AM
1993 Ford F-250
Unhappy Fitch Fuel Catalyst.
I tried posting this in another forum, but thought I would try here. Anyone seen these things before or tried them? I checked out the website, but can't seem to find where they tell you exactly what it does to make it work. Check it out, and tell me what you think.
__________________
  #3 (permalink)
Old 11-19-2006, 01:34 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Garage is empty, add now
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Sounds like fuel line magnets deja vu...
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #4 (permalink)
Old 11-19-2006, 05:06 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to allReAX is a name known to all
I think the state of Florida is sueing the manuf for fraud. Any case, magik pills only work in story books.
  #5 (permalink)
Old 11-19-2006, 07:24 PM
projectSHO89 projectSHO89 is offline
projectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to all
Yet another scheme to separate the guillible from their money.....
__________________
2001 F250 SD V10 4x4
HVAC FAQs: http://www.ford-trucks.com/forums/75...xpedition.html
Owner's manuals: https://www.fleet.ford.com/maintenan...ls/default.asp
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.” - Mark Twain
  #6 (permalink)
Old 11-19-2006, 08:52 PM
1993 Ford F-250
This stuff drives me nuts, at least with the magnets, they made up some junk about what they do to (supposedly) improve your mileage. All they tell you with this one is that it works, but apparently they don't know how. I'd bet these guys were trading cows for magic beans when they were younger.
__________________
  #7 (permalink)
Old 11-20-2006, 10:48 AM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
http://www.fitchfuelcatalyst.com/techinfo/ffcfaq.html
"The Fitch Fuel Catalyst is not a fuel additive. It is a special alloy that does not dissolve in fuel. On the alloy surface the fuel is reformulated to a state that is capable of a more complete combustion. As a result, the engine converts the chemical energy in the fuel to mechanical energy in a more efficient manner. The engine power is increased as a result and the toxic exhaust emissions are decreased, frequently by more than half."
IMHO. it's most likely a nicely reformulated BS as one would need higher than room temperature to do anything with most compounds in the gasoline, regardless of whatever catalyst is used. It probably contains at least one of these: platinum, palladium, or rhodium.
In any case, this is definitely better than a magnet, but it's probably just as useless.
Tags
anything, catalyst, fitch, ford, forums, fraud, fuel, truck, wwwfitchfuelcatalystcom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
