Oil Temp sending unit
on
Originally Posted by Kwikkordead
Instead of drilling the pan, why not remove the plug that is in the oil filter flange next to the block heater? Then you can see the temperature of the oil that is being sent to the engine.
on
There's also a plug in the block back by the oil filter that you can use. This would allow both oil temp and oil pressure to both be hooked up in seperate holes for the most accurate reading. The plug in the block is where I have one of my oil pressure senders hooked up. The plug is a square head, with 1/8" NPT threads, so the sending unit fits right in. Here's a pic of the location on the block, with my sending unit already installed:
on
Ron, yes it's right next to the bellhousing. You can see my oil filter on the far left side of that picture. The black cover below the sending unit is the cover over the torque coverter. Transmission behind it, to the right in the picture. The plug is on the driver's side. That picture was taken by sticking the camera through the driver's side wheel opening.
Both the oil filter housing plug and the one on the block should read approximately the same pressure, if not identical. I used the block simply because I've already used the plug on the filter housing for the supply hose to my oil guard bypass filter.
on
thanks alot...
mavman4
11-19-2019 04:03 PM
Finger__Rachet
07-03-2012 02:04 PM
1965F100(3onthetree)
03-29-2012 11:23 AM
polarspeed
04-07-2010 08:00 AM
