What kind of mileage does your powerstroke get????? - Ford Truck Enthusiasts Forums
Old 11-16-2006, 05:22 PM
Ken86F350 Ken86F350 is offline
Ken86F350 is starting off with a positive reputation.
I need to replace my 86 F350 diesel am looking at a 3/4 ton. It will be a commuter so mileage is a factor. What kind of mileage atre you diesel guys gettin????
Old 11-16-2006, 05:51 PM
dynarider1995 dynarider1995 is offline
dynarider1995 is starting off with a positive reputation.
There are many many other post on this subject. Look at some of the older posts and you will get an idea what people are getting, anywhere from 11mpg to 21 mpg
Old 11-16-2006, 07:14 PM
droptop396 droptop396 is offline
droptop396 is starting off with a positive reputation.
2007 F350, 2 weeks old 15-MPG.
No modifications,.........yet
Old 11-16-2006, 07:38 PM
Forester1 Forester1 is offline
Forester1 is starting off with a positive reputation.
Thumbs up
Quote:
2006 F250 Crew Cab SD - have about 3K on clock, seeing 13.5-15.5 mixed driving, 19.5-21.5 highway at 70 MPH, and around 12 pulling my 32' travel trailer. Very satisfied thus far. Only mod is by-pass coolant filtration.
Old 11-17-2006, 12:48 AM
TinyOne TinyOne is offline
TinyOne is starting off with a positive reputation.
2005 F350 DRW LB CC Lariat 27,000 miles 3.73 no mods. 13-14 city 16-17 Highway. 10-11 pulling my 38' fiver (22,000 lbs) over mixed terrain.
I'm happy with that. Still looking forward to get the new 6.4
Old 11-17-2006, 01:00 AM
eb2006's Avatar
eb2006 eb2006 is offline
eb2006 is starting off with a positive reputation.
2006 F250 CC SB 4X4 with 13K miles so far and totally stock. 14-16 mpg combo driving (city & highway), 18-20 mpg Freeway going 70MPH and 12-14 mpg pulling a small TT (5K lbs).
Old 11-17-2006, 01:22 AM
duffman77's Avatar
duffman77 duffman77 is offline
duffman77 is gaining momentum as a positive member of FTE.
Recorded all my fuel since new. Check out my spreadsheet from my gallery.
I usually travell 68-71 MPH on the highway.
Old 11-17-2006, 01:43 AM
hitecdan's Avatar
hitecdan hitecdan is offline
hitecdan is starting off with a positive reputation.
My 2003 F-350 FX4 Crew Cab long bed w/Leer Shell get an overall average of 16mpg. 1-13 city, 18-20 freeway. You'll get the best mileage on the freeway if you keep the rpm down below 2,000. About 1,800rpm = 60mph. If you have a heavy right foot, expect about 17 mpg on the freeway.
Old 11-17-2006, 02:27 AM
moldman7n moldman7n is offline
moldman7n is starting off with a positive reputation.
A friend has a 2003 2 wheel drive regular cab with manual trans. He gets 21 mpg all the time. He users it a mostly as a commuter truck also. I have a 2006 F350 6.0 auto trans 4X4. I got 15.5 with the LSD. With the new ULSD I am only getting about 14.5. On the highway empty, the truck can get 20 mpg if you keep it at 68-70 mph.
Old 11-17-2006, 06:33 AM
thats everyone, I appreciate it
Old 11-17-2006, 09:07 AM
m350 m350 is offline
m350 is gaining momentum as a positive member of FTE.
My 06' F-350, now with about 15,600 miles averages about 14 to 15 mpg,,it really seems to make a difference what kind of terrain you live around,,if its realatively flat mpg are around 18,, rather hilly 14 mpg or so,,when I was traveling about 70 miles a day ,,couple months ago,,It got up to 17.5 mpg one tankful,flater terraine ,,,lately short trips,,hills,, down to 14 mpg or so,,prob winter mix too.
Old 12-07-2006, 10:11 PM
iamtrace iamtrace is offline
iamtrace is starting off with a positive reputation.
mileage sucks
OK two weeks ago the dealer reflashed the computer under a recall. Well the mileage sucks, I took a 3000 mile trip and was getting 18.2 hand calculated with the cruse control on at 75. At 80 was 17.5 but not constant and on computer. Then the dealer reflashed the computer and I have only taken a constant speed controlled trip at 65 for 48 miles and was getting 16.4 computer calculated. I went back to the dealer and they say that is fenomable mileage and I should be happy to be gettin this mileage. Well I am not happy!!! If this the best they can do I willl be buying the new diesel Toyota. Gee I wonder why people go to foreign vehicles.
2005, F250, cc, Fx4, 22,300 miles, Diesel, short bed, 373 posi
Old 12-07-2006, 10:45 PM
eb2006's Avatar
If the re-flash did tank your mileage....that don't seem right. You know, there are a lot of things that influence mileage and one of the big ones would be the winter grade fuel at the pumps right now. I don't know for sure but I have read on other posts that that can do it...I don't know, mine seems to be fairly consistent. In regards to the Diesel Toyota....I have not seen that yet. Are they claiming better economy than the PSD with the same HP/TRQ numbers? If so, that is impressive. If not, then it is not a fair comparison.
Old 12-07-2006, 10:47 PM
KING's Avatar
KING KING is offline
KING is starting off with a positive reputation.
Month old '07 F350 with 3K on the clock and I am sitting on 15.4 right now.
Highest I was able to see was 15.6 but because I idle more than normal, I haven't seen higher.
Around 80% of my traveling is via highway.
Old 12-08-2006, 03:36 AM
thedaddycat thedaddycat is offline
thedaddycat is gaining momentum as a positive member of FTE.
'03 F-350 6.0 SC SB FX4 I get about 17-18 back road/highway with a 40 mile trip each way to work and back and a little bit of short trips mixed in. Offshore1 posted that he gets 26-28 but he's mod heavy and lives where it's fairly flat, drives around 60 mph on cruise if I recall correctly. The post that was in was one about deleting the cat if you care to do a search. There's another post here, "Need more MPG" I think, that has a lot of this same info in it...
I went and found it, here's the link...
http://www.ford-trucks.com/forums/55...etter-mpg.html
dont laugh (460 gas mileage) impact 1987 - 1996 F150 & Larger F-Series Trucks 167 02-03-2017 08:27 PM
What kind of gas mileage will my 7.3 IDI get? wdsloot2 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 02-29-2016 10:28 PM
fuel mileage dlackey 6.7L Power Stroke Diesel 4 08-14-2012 03:29 PM
Super Duty 20+ MPG - F350 Dually Diesel UaVaj 1999 to 2016 Super Duty 5 11-10-2010 08:38 PM
F350 gas mileage? fordfan758 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 10-31-2006 07:02 PM
Tags
2004, 2007, 477, 60l, 73, diesel, engine, f250, ford, kind, milage, mileage, power, powerstroke, stroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
