Alternator upgrade! - Ford Truck Enthusiasts Forums
Alternator upgrade!
Old 11-15-2006, 06:07 PM
tom1979 tom1979 is offline
tom1979 is starting off with a positive reputation.
Alternator upgrade!
I have been looking at upgrading or converting from a 60 amp oem alternator for my 79 F-150 (460) to a 100 amp 1 wire ford type alternator. What is the different other than to clean up under the hood. I assume it does away with the ext. regulator. Anyone, please explain further and how do you wire it up?
Old 11-16-2006, 08:37 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Quote:
Not sure what you mean by one wire unless you mean one large wire. They all have to have a control wire.
Here are two diagrams of systems, the first one is like yours now and the second one is of one with the internal regulator.
With a 100 amp system you will need the big wire to be 8 GA with a 12 GA fuse link.
Your system:
http://i54.photobucket.com/albums/g9...ulator1977.jpg
Internal system:
http://i54.photobucket.com/albums/g9...lator21977.jpg
Old 11-16-2006, 02:03 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Yes, I do not think Ford had a one wire alternator unless you are getting it from the aftermarket and it's been modified.
Old 11-16-2006, 04:27 PM
Yes, it is a aftermarket thru JEG'S. They call it 1-wire ford hybrid alternator. They have them for Ford and GM. So, does this mean they do have one wire or what?
Old 11-16-2006, 04:32 PM
buzzbait65 buzzbait65 is offline
buzzbait65 is starting off with a positive reputation.
yes, 1 wire to the positive of your battery, internal regulator, very clean and simple, Powermaster is the brand i believe, unless there are more makers of them now
Old 11-18-2006, 09:21 PM
Franklin2's Avatar
They have a special regulator inside the alternator to trigger it to charge. It has to detect automatically when to bring the alt "online" to charge, and "offline" when the engine is not running so it will not run down the battery.
You have to make sure you run a fairly large wire for these as was mentioned, and in some installations they can be finicky to get them to charge. What this usually means is you may have to rev the engine a little bit to get it to start charging after you just start the engine.
High Output Alternator? Totally Tuna 6.0L Power Stroke Diesel 3 08-01-2014 01:55 PM
alternator azpowerstroke 1961 - 1966 F-100 & Larger F-Series Trucks 7 07-13-2009 07:32 AM
fried alternator wire abd possible upgrade Green_Monster 1967 - 1972 F-100 & Larger F-Series Trucks 7 07-01-2009 09:13 PM
Ok to install circuit breaker between alternator and battery? body9599 1978 - 1996 Big Bronco 4 04-06-2005 12:19 PM
65Amp Alternator to a 80 Amp. Do I need higher gauge wire?? 89Bronco_EddieBauer 1978 - 1996 Big Bronco 1 02-18-2004 08:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
