99 Expedition 4x4 Issues
I have a 99 Expedition XLT; 4x4; 5.4L:
I've gone to my hometown mechanic and then to two FORD dealerships and they have all told me something different.
Over the weekend, I had to engage the 4wd (on the fly). After I got out of the quagmire, the 4wd would not disengage and go back to AWD. I tried everything, Park, Neutral, Reverse all while trying to get the transfer case out of low range. Then, the whole drivetrain sounded like it was going to fall out (it was binding up), and my spedometer was spiking. Finally, the transfer case just went into complete neutral on both drive shafts. These symptoms sound really bad, but they are detailed just like this on a couple of FORD's TSBs. After a little time, I got the transfer case back to rear wheel drive, but it was like my front wheels had locked hubs (I couldn't turn sharply at all). Come to find out, it's not hubs, but the front driveshaft binding in turns.
I have several FORD Technical Service Bulletins (TSB's) that I've got from the three mechanics I've been dealing with. Some point to GEM module, others to bad grounds, and finally a shift motor (on the transfer case).
Home Mechanic - $50 to test grounds and gem module; paid him.
Ford # 1 - Wanted to charge me $900 to replace the GEM module; I declined
Ford # 2 - Wanted to charge me $1900 to replace the entire transfer case; I was really pissed about this one and declined.
The computers all pull up the same errors: shift motor, shift motor plate, speed sensors in front/rear diff's. When I have the mechanic(s) reset the GEM Module (by clearing the codes), the "HUBS" unlock, or really the front driveshaft doesn't bind, for a short time until you start to drive 25' and then they lock back up. I'm not in Low range, but the front driveshaft binds and the Expedition "thinks" it's in 4HI all the time.
Where I'm at now:
I dropped my front driveshaft and am driving in 4HI (so really just 2wd rear and I don't have the binding)...so I put a bandaid on it. I've ordered a $100 shift motor online and hope this will fix it.
Anyone have any advice or experience with a similar issue like this? Thanks!
Where I'm at now:
jmmranger
1997-2006 Expedition & Navigator
31
08-26-2020 09:22 AM
lud04X
03-12-2020 12:09 PM
TExpedition45
18
06-10-2015 08:47 PM
