Front end bounce when braking @ 35mph
Did a quick search but didn't find anything (should I be looking in SD forum?)
Shocks have been replaced about 10k miles ago. Also replaced one rear spring when it cracked. Truck is pretty much stock. I noticed recently that when driving around 35-40 if I hit the brakes at about 60% of "stomp to the floor" pressure, the front end bounces like crazy until I hit about 30 and then it calms down. I can also let up on the brake until I'm under 30 or brake harder to get under 30 faster. Doesn't seem connected to the road condition.
Is this a rotor issue, pad issue, shock issue, alignment issue, or something else?
In the past 2k miles I did change the seals, bearings, and hubs up front (courtesy the help on this site) and did not get an alignment - I don't drive it much. Is this the problem?
There was a discussion about this last week I think. If I remember correctly, this was one of the possible cures.
http://guzzle.rbmicro.com/cu.html
sfc2001
22
05-09-2023 02:36 PM
ExPACamper
03-30-2016 01:05 PM
