stripped head bolt
stripped head bolt
Well once again I'm back for another round of questions. This is my problem. I have recently rebuilt my 223 in my 58 ford. Now the problem is that I already blew the head gasket. What happened was when I had the machinist do the work he somehow screwed up the threads on one of my head bolts. I cleaned up the threads and torqued it down. The threads are now stripped. If I was to drill this out what size bolt and thread pitch do I need to retap it at? And if i do this will I risk going to thin and hiting the water jackets? Any help will be appreciated. thanks and Happy Fording!!!!!!!!!--jax
on
stripped head bolt
One option is to tap for a slightly larger metric size.
If that doesnt hold then screw in a stud coated with JB Weld. Go to their web site for the proper product selection.
Ive also heard of filling the hole with JB and then drilling and tapping but that requires precision.
Since the machinist screwed up (or were the threads already pretty corroded?) will he do the repair? In that case helicoil or resistance welding in a stud are options.
stripped head bolt
i have used helicoils for years, and have nothing bad to say about them...the important thing to remember when using heli-coils are to drill and tap to the recommended sizes, and to drill the hole deep enuff. if all the above conditions are met, a helicoil is as good if not better than the original threads.
Robert
Robert
stripped head bolt
If Volvo is willing to use Helicoils in every hole including the head bolts on they're marine diesel engines they'll probably hold up to a 223. You shouldn't have any problems. Talk to your machine shop and see if they'll cover it. If not you may want to consider a different shop. Good luck, Rich.
