Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Alaska Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Alaska Chapter Join Chapter, Leader: bearman113
  #1 (permalink)
Old 11-14-2006, 03:21 PM
murray44 murray44 is offline
Garage is empty, add now
murray44 is starting off with a positive reputation.
Cool missing in overdrive
I have a 4.6 now that it's cold The truck starts missing in overdrive on up hill at 60 to 65.The hills from valley to anc .Turn off od runs fine ,Whatsss up
  #2 (permalink)
Old 11-15-2006, 12:40 AM
mlb4966's Avatar
mlb4966 mlb4966 is offline
2011 Yamaha MTX
mlb4966 is starting off with a positive reputation.
Hi Murray. Is the 4.6 in the F150?? If you do not get any answers you might want to ask this same question in that section.
__________________
Mike B
1999 F350 CC DW 2V V10 - 2000 F350 CC - Flatbed 7.3
2002 F250 SC - V10 - 2004 F350 CC - 6.O (Terd-Injectors)
2006 F350 CC Lariat - 6.0 (Terd 2 - Head Gasket)
2011 F350 CC 6.2 - The future shall tell
  #3 (permalink)
Old 11-15-2006, 11:52 AM
No it is in a F250 4x4 with 48,000 on it
  #4 (permalink)
Old 11-15-2006, 11:55 AM
Sorry it is a 1999
  #5 (permalink)
Old 11-19-2006, 01:26 PM
mlb4966's Avatar
2011 Yamaha MTX
Ok I would suggest posting this in the Super Duty section. Someone there might had a suggestion
__________________
Mike B
  #6 (permalink)
Old 11-19-2006, 09:09 PM
arcticoffroadingfish arcticoffroadingfish is offline
arcticoffroadingfish is starting off with a positive reputation.
the 4.6 is not a superduty engine it would be the light duty
__________________
There aint nothing better than kicking back and muddin with some friends!!
  #7 (permalink)
Old 11-19-2006, 09:11 PM
what are your rpms while you are in overdrive? and are there any other symtpoms that its has?
__________________
  #8 (permalink)
also are you in 4hi or 2hi
__________________
  #9 (permalink)
Old 11-20-2006, 12:53 PM
Rpms ? No rpm guage running in 2hi .Just start missing on a incline
  #10 (permalink)
Old 11-21-2006, 04:11 PM
what is your gear ratio in the rear axle you just may be at too low RPM, its possible anyway or you may just be hitting ice and then pavement on the incline. does this happen on any incline or just this one? if its just that one try another incline and see what happens.
__________________
  #11 (permalink)
Old 11-22-2006, 02:31 PM
on any incline, no ice on the road, If I keep my speed up Like 70 run fine I like going the speed limit,gear ratio? It is a stock truck from ford I think they would put the right rear end in but never know .
  #12 (permalink)
Old 11-30-2006, 10:21 PM
do you have any check engine light? it is possible that you have a bad coil pack and it is arcing to the side or a air leak around the intake or a hose...
__________________
  #13 (permalink)
Old 12-06-2006, 02:35 PM
Had snap on code reader on it ,it shows on missing ,must be trani will take it there and see what they say
Tags
06, 2004, 46, 60, chapters, drive, f150, ford, missing, missinng, overdrive, truck, uphill
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
