Rough Idling 1997 4.0 sohc Ford Explorer
Old 11-14-2006, 12:34 PM
mossy007's Avatar
mossy007
mossy007 is offline
Cool Rough Idling 1997 4.0 sohc Ford Explorer
I have a 1997 Ford Explorer which has a rough idle.I have had a new engine fitted but it still idles at around 500rpm and will sometimes stall when i go to pull away.There is no CEL on at all,i have replaced the IAC and cleaned the MAF,replaced the air filter, TPS sensor,Plugs and leads.I was wondering if it was the PCV or EGR valve.This happens to the truck when its hot or cold,so im not sure what the hell's going on. If anyones got any ideas i would be very grateful.
Old 11-14-2006, 10:16 PM
oojbearoo's Avatar
oojbearoo
oojbearoo is offline
had the same problem with my 96 my EGR was sticking
Old 11-14-2006, 11:25 PM
pirtlegt's Avatar
pirtlegt
pirtlegt is offline
Lightbulb
The 4.0 SOHC doesn't have a PCV valve. I am having a simillar problem with my 97 4.0 SOHC. On a cold morning, it does not want to idle until it warms up. After that, she runs great. Was told it might be the coolant temp sensor that runs to the computer, (it has 2, 1 for dash gauge, & 1 for computer) haven't tried yet, but will post when I do. Hope this helps u out a little b4 u think about a new MAF ($100.00).
Old 11-15-2006, 12:24 PM
mossy007's Avatar
mossy007
mossy007 is offline
Can anyone confirm wether or not i have a PCV valve.Im quite sure i have as in my service book its says its changed on the 60,000 mile service.
Old 11-15-2006, 12:47 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
If it doesn't idle until it warms up its probably an intake manifold gasket leak. The 4.0 SOHC is notorious for the gasket leaks.
As far as the OP, check for vacuum leaks.
Old 11-15-2006, 12:53 PM
mossy007's Avatar
mossy007
mossy007 is offline
It idles the same hot or cold,never surges just a low idle speed !! So im not sure if its the O ring gaskets as the engine was brand new from ford.
Old 11-15-2006, 03:23 PM
MisterCMK's Avatar
MisterCMK
Check for vacuum leaks
Old 11-16-2006, 12:19 AM
mossy007's Avatar
mossy007
mossy007 is offline
Ok thanks i'll have a look this weekend.
Old 11-16-2006, 12:24 AM
Racerguy's Avatar
Racerguy
Racerguy is offline
The 4.0 SOHC PCV valve is at the back of the intake manifold. You can see it and feel it from the passenger's side of the engine. It has 2 hoses with a TEE going to it.
Like MisterCMK said the most common cause of a 4.0 SOHC idling rough and stalling, especially cold, is bad intake gaskets. I've replaced lots of them.
Jim Adams
04-06-2015 10:47 PM
tc76934
1997 - 2003 F150
27
03-13-2013 08:09 PM
donaldson202
08-02-2005 06:23 PM
ashorn
1983 - 2012 Ranger & B-Series
03-18-2004 07:00 PM
savvy5473
03-11-2004 03:38 PM
Quick Reply: Rough Idling 1997 4.0 sohc Ford Explorer
