11-20-2006, 10:44 AM
I had a fuel pump go out on my explorer and it acted the way you are describing. I had the same codes you have and I couldnt figure out what was wrong. It had the codes for about a month before the symptoms showed up on a trip. I pulled off the Interstate and it died at the stoplight. Would start and barely run. It would pick up and go and the higher the RPM the better it would run. It would run ok for a while, then it would act up. When the tank was full it would be ok. When the pump would start to heat up it would start stumbling again. I changed the pump in the parking lot of an Auto Zone on a Sat. night in San Antonio Tx. 300 miles from home. (not much fun by the way) All problems went away.
