Replace Slip yoke
Old 11-14-2006, 11:30 AM
FX4Jim3's Avatar
FX4Jim3
FX4Jim3 is offline
Replace Slip yoke
I have a 04 screw with the well known driveline slap.
Can I replace only the slip yoke or do I have to repace the hole drive shaft?
Thanks
Old 11-16-2006, 07:58 PM
Mikec35's Avatar
Mikec35
Mikec35 is offline
Try lubing it first, before going through the expense of replacing
Old 11-17-2006, 05:12 AM
FX4Jim3's Avatar
FX4Jim3
FX4Jim3 is offline
Thanks Mike35
Been there done that several times.
After several ford dealers and greaseing ,Ford said that it was normal.
So I will fix it my self.
After 30 years of ford trucks this might be the last one.
Old 11-17-2006, 05:25 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Chevy's have had driveline slap and axle wrap for years, the Titan also has these problems.
btw...the next time your dealer says "it's normal" ask him to take a new one for a test drive. If it doesn't slap...you then have an issue they should solve. Re-setting the rear end lash solved it on mine.
The only cure I know of for axle wrap is traction bars.
Old 11-17-2006, 11:35 AM
triple8's Avatar
triple8
triple8 is offline
I had a thumping when taking off from time to time. The dealer told me the slip yoke was wearing, at 4K or so. They ended up replacing the rear shaft.
Old 11-17-2006, 12:43 PM
Mikec35's Avatar
Mikec35
Mikec35 is offline
They lubed mine and it is better, but it still thumps from time to time. When I took it in to be checked out they told me that they needed to order a new slip yoke. I came back to get the new yoke installed and left my truck. Went back later to pick it up and they told me that all they needed to do was lube it. They know there is a problem, but I don't believe they have an accurate fix. I've still got 2 years and 20 miles on the warranty. I think I'll wait to see if they develop a true fix. Mine probably makes more noise then I realize, listening to the stereo probably covers it up!
Old 11-18-2006, 05:57 AM
FX4dude's Avatar
FX4dude
FX4dude is offline
i had a new driveshaft made for my 04 fx4 because there was a lot of "play" in my u-joints. it sucks you have to replace the whole driveshaft, but at least now i have a stronger driveshaft with 1 ton spicer u-joints that are replaceable . . . thicker wall tubing and welded yokes, instead of the spin-welded yokes on the factory shaft.
Old 11-18-2006, 06:14 AM
PC Poppy's Avatar
PC Poppy
PC Poppy is offline
Originally Posted by FX4Jim3
Thanks Mike35
It is NOT normal. Don't fix it yourself if it is still under warranty. They know there is a problem , in fact in another forum there is reference to the nickle coating on the spline shaft that is the culprit. Greasing is a temp fix and lasts only a month or so. The fix IS - replace the entire driveshaft assembly. You may have to go back screaming 4 or 5 times and let them grease the sucker but in my case ofter letting them grease it 4 times I finally said "look, it is wrong from the start and I want it fixed as my warranty expires soon". I said that I would bet it can be fixed if I was paying for it. The dealer contacted Ford and had a new driveshaft installed the next day. They said that the shaft was flaking off rust anyways. Whether this was a contributing factor in their decision, I can't say for sure. Never a problem with it again. Smooth as silk on acceleration from a stop. The list on that part was over $600 CAD
Old 11-18-2006, 07:24 AM
TXFX4's Avatar
TXFX4
TXFX4 is offline
do you have the part#?
Old 11-18-2006, 10:20 AM
YOMAN's Avatar
YOMAN
YOMAN is offline
Mines replaced whole driveshaft and was told that slip yoke is improved and solved the problem..so far over 7,500 milages with no problem!
DO search under my handle name YOMAN or driveshaft tsb you ll find some TSB #.
Later!
YOMAN!
Old 11-19-2006, 04:03 AM
FX4Jim3's Avatar
FX4Jim3
FX4Jim3 is offline
Thanks guys
But I guess ford wins this time 47,000 mi and past warrenty.
So does any body know if I have to replace the hole shaft unit or can I just replace the yoke.
96f150
1997 - 2003 F150
08-12-2012 06:06 AM
cyclospot
10-13-2007 01:44 PM
OX2
04-29-2005 01:18 AM
wgotthardt
1997 - 2003 F150
02-11-2005 06:41 PM
keys
12-06-2004 06:41 PM
Quick Reply: Replace Slip yoke
