Different Hp And Trq In 450 And 350
#46
#48
#49
I was able to get a little more info on the reason why the 450 has been de-tuned.<O</O
I showed my Ford rep the flyer that was sent out to prospective buyers. Showing him the lower HP/Trq of the 450. He placed a call to his Ford Engineering rep to find out some more info as to why this was done.<O></O>
The Engineer told him that the 450 had been detuned because it could produce the same "equivalent" power as the 250/350 but at a much lower RMP due to the lower gears. So I guess the 250/350 and 450 must have close to the same HP/TRQ at the RW's, only the 450 does this at a much lower rpm. I think this may have also been stated by some of the other posts.<O></O>
Now just need to figure out how to increase the power a little.<?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><V
My Ford rep also said the pricing will be released on 12/11.<O</O
<O</O
<O</O
#50
Thank you 1968. I think thats what we all needed to hear! So basically, if the 450's 6.4 cranks out the same torque at the rear wheels at a lower RPM thanks to the rear end gearing. This will make it unnecessary to rev the 6.4 as high, thus allowing less wear and tear on it, and less wear and tear on the rest of the drivetrain componets.
Making sense here?
Making sense here?
#51
Making sense here?
Making sense here?
Sorry but no
#52
#53
#54
Originally Posted by Customz
maybe it has a completely different hp/tq curve that makes more torque down low and can't make as much up high. With a fatter curve the peak power may not be necessary. There has to be a better technical explanation than 'lower gears'.
#55
#56
#57
obviously the lincoln towncar, but why use a different 460?
My point was the 450/550 may have more area under the curve than the 250/350. Again, I am just brainstorming. In my opinion, the #s are just for bragiing rights as the 6.0 did the same amount of work for the past 4 years with 325/570 and the 7.3 did it long before that. The 6.4 may be able to do it a little faster, but we all know the trade-off.
#58
Becuase Ford has to warranty the drivetrain.
Ford also has to provide a competive rated product to Dodge and GM in the F250 and F350, hence the need to have those engines "cranked up" a bit when they likely could have used the engine with the lower ratings across the board.
#60
__________________
Good point. The power on these LIGHT duty trucks is getting crazy. It is getting to the point where there needs to be training for some of these clowns to drive the weight these trucks are capable of towning
__________________
