Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-13-2006, 07:01 PM
Argintessa Argintessa is offline
Garage is empty, add now
Argintessa is starting off with a positive reputation.
1962 Engine ID
I'm having problems Identifying an engine in my 1962 Ford 250 Truck. It has C4AE (high riser heads). I think its either a 406/410/427/428. Its a big FE engine. What were the available ford engine options for a 1962 truck???
  #2 (permalink)
Old 11-13-2006, 10:16 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
None of those was available in a truck in '62.
  #3 (permalink)
Old 11-13-2006, 10:27 PM
What are the available engine options? The truck has C4AE heads (high riser) which is baffling to me. Weren't 360's typically put into trucks in 1962.
  #4 (permalink)
Old 11-14-2006, 05:38 PM
360s were '68 or later, methinks.
In '62 you would have been looking at a y block, 292. MAYBE a 352.
Now highriser heads were never offered on a 352, and a 427 highriser didn't exist in '62. You have a swapped in something there. Any signs of rewelded or different engine mounts?
I could be any FE, but 352/360/390 would be the most likely, as those are the ones as numerous as sand on the beach. 406? 427? Look for cross bolts just about the oil pan rail. 428?
How does this thing run? Will it fog the tires with half throttle? What carb and intake does it have? Transmission?
This needs to be moved to the FE threads, as this is in the wrong area, btw.
  #5 (permalink)
Old 11-15-2006, 11:24 AM
99F150 99F150 is offline
99F150 is starting off with a positive reputation.
A 1962 F250 would have one of three engines. 1. 223 inline six, 2. 262 inline six or 3. 292 Y block V8 with either 2 or 4 barrel carb. The 4 bar. carb was used on the heavy duty engine.
What is the vin code? this will tell the engine. The 4th digit of the serial number.
The FE engines were not factory options until the 1965 model year.
Dan
  #6 (permalink)
Old 11-15-2006, 03:29 PM
I have just broke the block down and it turns (the flywheel) so its not blown. The heads are high riser and look good. I see a casting on the front of the block that reads C7ME-A. When I removed the flywheel I see the typical 352 number with the number 25 along side of it. I measured the bore and it looks to be 4 and a 1/8 which looks like a 390 to me.
  #7 (permalink)
Old 11-15-2006, 04:10 PM
Help Engine ID
The serial number for the truck is F25JR232463 Model F250 Trans Axle F 26. When I removed the flywheel I saw a casting number 352 with a 16 right above it. There is a C7ME-A casting on the bottom of the block. I measured a 4 1/16 bore and a 3 5/8 Stroke. I think its a 390. Does that make sense???
  #8 (permalink)
Old 11-16-2006, 08:43 AM
F25= F250 4x2, J= 223 inline 6, R= Sanjose assembly plant, 232463= build during month of December 1961.
Trans code F= T98A Warner 4speed., Axle 26= 4.88 rear axle ratio.
I had a 1962 Custom Cab Unibody F250 that was built with same drive train.
Dan
  #9 (permalink)
Old 11-16-2006, 10:25 AM
Sport45's Avatar
Sport45 Sport45 is offline
Sport45 is starting off with a positive reputation.
Check the stroke again. You're about halfway between a 360 (3.5") and a 390 (3.75").
__________________
'00 F250, CC SWB 4x2, V-10.
'83 F100 SWB 4x2, 302 AOD.
<= "After"
Tags
1962, 390, 477, cid, decoder, engine, f250, ford, id, identification, motor, options, ranchero, sd, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
