Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Minnesota Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Minnesota Chapter Join Chapter, Leader: fordpower88
  #1 (permalink)
Old 11-12-2006, 04:02 PM
neoflee's Avatar
neoflee neoflee is offline
Garage is empty, add now
neoflee is starting off with a positive reputation.
Question 87 f150 rear wheel bearing help,eden prairie
The truck is in the air and the rear dif cover is off? how do i pull the c-clip off the axle? how do i get the axle out? Do i need to pull the gears out? I have a hayns manual, but Im kinda confused? Im new at this stuff... any healp with be greatly apreciated..
  #2 (permalink)
Old 11-12-2006, 07:36 PM
wiseguy50 wiseguy50 is offline
wiseguy50 is starting off with a positive reputation.
go to the library and ask to use the alldata program on their computers.
its free. they will help you get started. all YOU have to do is type in the info you are looking for. its real easy. just follow the directions.
  #3 (permalink)
Old 11-14-2006, 05:27 PM
DOUBLEF222 DOUBLEF222 is offline
DOUBLEF222 is starting off with a positive reputation.
All U Gotta Do Is Push The Axle In Where U Can See The C-clip And Just Pull It Out. No Special Tools Needed
  #4 (permalink)
Old 12-20-2006, 06:54 PM
385seriesHemi's Avatar
385seriesHemi 385seriesHemi is offline
385seriesHemi is gaining momentum as a positive member of FTE.
A small magnet makes it pretty easy to reach in after you push the axles in to get the clips.
IF you want a good library for automotive reference books go to Hennipen county Library on York avenue in Edina they have a crap load of books plus Alldata. I go there quite frequantly.
  #5 (permalink)
Old 12-20-2006, 07:11 PM
But remember you have to take the pinion pin out from the case that keeps the pinion gears in mesh/place with the axle side gears.
heres a list
1. Pinion pin- held in by a retainer screw( might be a 8mm I could be wrong)
2. Push axles in
3. Take C clips out
4. Pull axles out
Just reverse what you did for installation its easy, rear axles are the easiest thing on a vehicle I think.
When the axles are back in take some brake clean and spray the ring and pinion along with the inside of the pumpkin down ALOT so you clean it out and then put your new fluid in after its sealed. Also when spraying have someone rotate the wheel so it turns everything inside the pumpkin so you can get everything cleaned.
Tags
87, bearing, f150, rear, replacement, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
