Decisions, decisions!!! Anyone got some advice/suggestions??
Project is an F1. Will have upgraded IFS (either MII or Dakota) and 9" rearend, probably 4 speed trans. My delima, so to speak, is which engine to use. I have both a 302 and a 351C sitting in the garage (assuming both are rebuildable, but neither is dis-assembled or checked etc yet). Being a racer at heart, I'd really rather have the 351 for performance. BUT, being limited financially, I'm hesitant to take that path - I know the 351C will cost more to rebuild/fit to the chassis but I'm wondering if I'm not even aware of all the potential problems. Can anyone that's gone through this 'for-warn' me?? and possibly save me some time/money etc.
I know the rear sump pan for a cleveland is available but more expensive. Similarly, I believe headers for the Cleveland are significantly more $. I realize the differences in just the rebuild as well, but I think the differences there correspond to their relative performances. (I'm not talking about anything extensive, just a slight CR increase on the Cleveland should take care of what I'm after for performance).
I guess the 351C also appeals to me for the simple reason its a path less taken - I just want to make sure how much that path might cost me!!!
Thanks, in advance for any comments/suggestions. I'm 'all ears'!!!
It sounds to me like you REALLY want the 351 so I say go for it. If you don't you'll always think " I coulda had that 351". If you go ahead then you won't be doing another engine swap in a couple of years. It's only money and if you spend it all you don't have to worry about it going to some relative who doesn't deserve it.
Bob
Bob
The 351C is just plain sexy! It is a much better looking engine! We know a lot more about the Clevelands now than when they were popular. You can build a sweet motor without resorting to super trick parts and rare and hard to find parts. The two barrels heads are better for the street and are easy to find. If you are resourceful and go to a few swap meets you can probably pick up used parts that are a bargain. I can't tell how hard or how harder it will be to put the Cleveland in but I personally feel that you will be more satisfied WITH THE CLEVELAND. I believe the swap has been done before so you should be able find out the problems before you start. Do lots of research before you start spending your money. Then make your own decision based upon your desires, skills, and money.
Restoring at the speed of a slow sick snail !
Charles in Pensacola
57 F100 adding Blown 312 auto
86 F150
86 F150
Give me the Cleveland
You will give me the Cleveland...
Shoot the hypnotism classes may have been worthless.
I like the reactions I get when people ask me what I have in my 56. It's kind of a badge of honor or something. I bought mine with the 351C in it so I have no idea how hard it was to install. It does look good in there though.
Craig
Craig
I have a 351C in my 56. I absolutely love it. It will bolt in the same spot as a 302. Mine has 2 barrel heads, Edelbrock Performer intake, Holley 600, Compcam 268H cam, AOD, trans, and 3.50 geared 9" rearend. It gets up to 16-18MPG and will roast the rear tires. It looks like a Big-block.
Now the bad news, parts are more expensive and harder to find than a 302. Late model Mustangs made it popular to have a Ford engine again. Their parts are cheaper!!!
Hey 'truckfarmer'..... If you don't mind, let me know what oil pan and headers you used. I realize the F1 'fit' will be slightly different, but basically the same. I'd also be interested in any other special parts needed or issues that had to be resolved!
banderson@climate-engr.com
thanks for the input everyone!!
I am using a Camaro subframe and still was able to use the stock front sump pan. The Econoline vans and 4x4 trucks were available with a 400 engine that used the rear sump oil pan.
I used the stock car manifolds but want to replace them with Sanderson headers. Sanderson makes 4 kinds of 351C headers.
