'59 F100 exhaust manifold - Ford Truck Enthusiasts Forums
Old 07-28-2002, 12:05 AM
rallyman rallyman is offline
rallyman is starting off with a positive reputation.
Does anyone know where I might locate a reasonably priced left side exhaust manifold for a 292 Y- block in a '59 F100? I don't want to spend a great deal as the ol' 292 will be coming out in the (hopefully) near future to make room for the 351 / C6 that I have waiting for it! Any help is much appreciated!
Thanks,
Craig.
'59 F100
'91 Bronco 5.0 SVO
'99 F250 V-10
Old 07-28-2002, 03:18 AM
darkman darkman is offline
darkman is starting off with a positive reputation.
[updated:LAST EDITED ON 28-Jul-02 AT 03:19 AM (EST)]Are you looking for the truck manifold that exhausts out the front to the crossover? The drivers side or passenger side?
Restoring at the speed of a slow sick snail !
Charles in Pensacola
Old 07-28-2002, 01:51 PM
Charles,
I need the actual exhaust manifold - the part that attaches to the head - it does have the exit for the crossover pipe - not sure if they all did this or not (??). I need the driver's side - badly. Mine is split open between the two center cylinder ports and the paint is burning off the matching intake runners - YIKES!!
Thanks,
Craig.
Old 07-28-2002, 01:59 PM
Craig,
I know where one is but it would be a month before I could get it. I believe that it is ok but until inspected I can't promise. Also the shipping would be high from Florida. These are very common and someone should have one closer to you. If not I'll help.
Old 07-28-2002, 03:14 PM
Charles,
Thanks for the info and the offer......the time is not really an issue as I am leaving for vacation in a week - and I will be gone about 3 weeks. I'll check around - old truck junk yards aren't real common around my area of So. Calif, but who knows what may turn up. I'll keep it in mind and thanks again!
Craig.
'59 F100
'91 Bronco 5.0 SVO
'99 F250 V10
Old 07-29-2002, 10:25 AM
Ironwolf21 Ironwolf21 is offline
Ironwolf21 is starting off with a positive reputation.
I am not sure if it will fit but I have one from a '55 239 you can have for shipping cost. I can send both sides.
Old 07-29-2002, 05:28 PM
Thanks, but I too have absolutely no idea about the interchange. Is the 239 a Y-block engine? I am not even sure about the interchange between a 292 / 272/ 312.........anyone else know?
Thanks,
Old 07-29-2002, 09:22 PM
Kenny's Avatar
Kenny Kenny is offline
Kenny is gaining momentum as a positive member of FTE.Kenny is gaining momentum as a positive member of FTE.
Hi,
272, 292, and 312 all share the same block, and are interchangeable. The 239 is a Y-block, but I don't know if it is interchangeable with the others. It seems to look the same from some pictures I've seen.
Old 07-30-2002, 10:59 AM
amorgan351 amorgan351 is offline
amorgan351 is starting off with a positive reputation.
I have a drivers side crossover style manifold in decent shape from a 292 yblock under my workbench. I went to dual exhausts, so I capped the passenger side and got a downer for the driver side. It is yours for shipping.
Al
No Name 57
Old 07-30-2002, 11:32 AM
[updated:LAST EDITED ON 30-Jul-02 AT 11:34 AM (EST)]Thanks! I'll drop you a line and we'll figure out the details!
Thanks again to everyone!
Old 08-19-2002, 01:29 AM
1959FordBigbackwindow 1959FordBigbackwindow is offline
1959FordBigbackwindow is starting off with a positive reputation.
i got a set of y block headers that are the newer style. I had big ideas of just leaving my truck stock till I saw some of the trucks at all of these shows. let me know if your interested.
Old 08-19-2002, 01:38 AM
Exhaust manifold options for 55 F100 w/ 292 & 3sp on column jaggermk 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 11-02-2014 07:54 AM
1964 F100 292 Exhaust Manifold ?? slckkw 1961 - 1966 F-100 & Larger F-Series Trucks 4 11-18-2005 03:55 AM
292 intake manifold pjd822 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 10-24-2005 03:15 PM
351w into '59 F100 rallyman Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 16 08-27-2002 03:02 PM
59 f 100 questions Craig 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 01-26-2002 11:00 PM
Tags
59, exhaust, f100, manifolds
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
