"Diode Suppressed" Solenoid help - Ford Truck Enthusiasts Forums
Old 11-09-2006, 11:24 PM
fozzy's Avatar
fozzy fozzy is offline
fozzy is starting off with a positive reputation.
My father in law replaced a battery in his 1986 f150 302 EFI, and he said it wouldnt crank, then he realized he forgot which way the wires were on the solenoid. The solenoid is marked "Diode Suppressed" or something like that.
He left the key on and went inside, when he came back to it the alternator was just smoking (The engine was OFF). Any diagram available? Any tips?"
so anyway I am thinking he has a short in the alternator that killed his first battery, when I gave him a fresh one to use, it smoked the alternator.
When he lets go of the key while cranking the truck dies. Ok I know this is long. Does anyone have a diagram for how to rewire the solenoid back? I know the large wires and how to get the key switch right, but the rest I do not know. I only am familiar with the older Fords.
Old 11-09-2006, 11:41 PM
built 80 f250 built 80 f250 is offline
built 80 f250 is starting off with a positive reputation.
the battery cable on the solinoid can go on ether post as long as the wire to the starter is on the opposite side and the little red wire from the ignition goes on the post s if there are two of them
Old 11-09-2006, 11:55 PM
fozzy's Avatar
apparently there are several wires. WHat do you think about the smoking alternator? are these alternators internally regulated? Or is it an external?
Burning through 3G alternators - Help! guisepi Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 07-20-2015 01:44 AM
90 f250 300 no spark , any ideas? JayzDaddy 1987 - 1996 F150 & Larger F-Series Trucks 7 10-23-2014 12:25 PM
Help!! Need Ignition Suppression Resistor and no one has it ford_medic 1987 - 1996 F150 & Larger F-Series Trucks 19 09-10-2013 11:38 AM
Rewired 67...won't turn off??? 67F250RET 1967 - 1972 F-100 & Larger F-Series Trucks 2 02-04-2013 07:23 AM
engine cranks with key in "run" position nissan4life 1973 - 1979 F-100 & Larger F-Series Trucks 13 09-20-2009 08:02 PM
Tags
1986, diode, diodesuppressed, econoline, f150, ford, iode, solenoid, solenoids, suppressed, suppression, supressed, surpressed, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
