You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I Am Planning On Buying Some Long Tubed Headers..how Much Hp Should I Expect To Gain..and I Already Have Full Exhaust So What Should I Expect For Loudnes A Lot More Or No
Believe it or not, you won't see a huge increase in HP. Unlike a 5.0 Mustang, adding long tubes to the Lightning just doesn't "wake up the engine", like it does to the Mustang. That's because the stock exhaust on the Gen 2 Lightnings breath pretty well in stock form, and it isn't until you are generating quite a bit of HP over stock that you see more than an incidental increase in performance with the addition of long tubes.
As for sound, you'll have a marked tone difference. Long tubes produce a deeper, more robust sound. Volume will increase also, especially if you choose a no-cat setup, straight back to the mufflers.
Stewart
__________________ The Brotherhood of FTE <-click the link 1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft 1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff 2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes Never Fry Bacon NAKED!
Long tubes show advantages once you are making about 500hp or more...below that point, they don't show significant gains, especially since they are a PITA to install.
But the bling factor does increase.
__________________
97 Expy XLT, 5.4L, 2WD | Intercooled Procharger| 10.5 psi | Full fuel system mods | 4.10 LSD | Tuned by Swanson Performance
