Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 11-08-2006, 11:57 PM
member33094 member33094 is offline
Garage is empty, add now
member33094 is starting off with a positive reputation.
Emergency Fuel
I heard diesel engines can run on vegetable oil and was wondering if you needed a little more fuel to get to the next station could you just dump a bottle of Crisco in your tank without causing damage?
  #2 (permalink)
Old 11-09-2006, 08:41 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Yes you could
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #3 (permalink)
Old 11-09-2006, 05:03 PM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
Well that depends on a lot of things. First, what truck do you have. On a pre-powerstroke diesel, a bottle of canola would get to the next station, if its above about 80 degrees outside. However, any kind of hydrogenated oil will solidify. You need non-hydrogenated oil, and don't run too much b/c you can burn up an injection pump quickly if you don't heat it.
__________________
1988 F350 7.3 Crew Cab 4x4 Dually C6
1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual.
  #4 (permalink)
Old 11-09-2006, 09:19 PM
Quote:
What about a 6.0 powerstroke, and what is b/c?
  #5 (permalink)
Old 11-09-2006, 09:44 PM
A 6.0 might run on it, if its extremely hot, but I would not risk it. 6.0 powerstrokes have electronic oil pressure controlled injectors, and since veggie oil is so thick, they will not be able to pump enough fuel into the engine, and will probably give out overworking themselves. This is even worse in a 6.0 than a 7.3, as they have weak injectors anyway. In an old truck, it just has an Injection pump pumping the oil/diesel through simple injectors with no electronics necessary, so they just work harder and the problem of the thicker fuel is remedied with a heavier foot on the pedal. Also, in cold weather, the Injection pump will fail. Believe me, I've been put beside the road with that stuff in my pump and it got cold one night. However, in my old truck, the Injection pump was fixed for $300, while a 6.0 could easily get into the thousands, on top of voiding your warranty.
__________________
Tags
diesel, emergency, fuel, oil, vegetable
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
