Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Ohio Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ohio Chapter Join Chapter, Leader: RUNVS
  #1 (permalink)
Old 11-08-2006, 08:18 PM
Pikeboy98 Pikeboy98 is offline
Garage is empty, add now
Pikeboy98 is starting off with a positive reputation.
'88 Ford F250 - 302 Smoking
My 302 in my truck just started smoking. It is smoking out the tailpipes. This has to be bad. I had it checked out and the mechanic said that cylinder #7 has low to no compression in it and the new plugs in it is all fouled up already.
Is there any saving this engine?? Can I do a cheap rebuild to keep it running or is it in need of an overhaul??
My brother has a 302 from a wrecked '88 Mustang. It is the same year as my truck, so I figure this could be a fairly easy swap. Any leads, ideas, sources or other posts that I could review??
  #2 (permalink)
Old 11-08-2006, 11:55 PM
F2504x4's Avatar
F2504x4 F2504x4 is offline
2002 Ford F-250
F2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud of
Hi and welcome to the ohio chapter,
From what I know of the 302's the truck motors are differant , cam, timing etc, oh yea pollution control set-up's. you would do better getting another engine out of a same year truck for a straight forward swap IMO
not saying the car engine would not work but that there are differances.
  #3 (permalink)
Old 11-09-2006, 05:10 AM
d79f150 d79f150 is offline
d79f150 is starting off with a positive reputation.
Yes you can do that swap... Just use the cam & intake from your truck. Or better yet buy a "truck" cam for the stang block that way you can keep your torque #'s up where they should be.
IF you don't change the cam the truck won't seem to have any take off power because a mustang is a whole lot lighter than a stang. The block & the heads are the same though.
__________________
1979 F-150 400 (mildly built)
1993 F-150 5.0 (getting built this winter - $$ permitting)
  #4 (permalink)
Old 11-09-2006, 11:07 AM
Thanks!!! That is good information. I am not sure what I want to do with the truck. PArt of me says to buy a rebuilt engine with a warranty and keep the truck for awhile. Part of me says make it run while I build my house next year and then just get rid of it. The first part is the kid in me wanting a 4x4 to play with forever and the 2nd is the finance part of me talking $$$.
Any other words of wisdom are welcome. Thanks for the comments.
Tags
2005, 250, 302, 88, 88fordtruck3o2, bad, f150, f250, ford, ideas, mustang, proud, smokes, smoking, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
