Aftermarket MPG Gauge? - Ford Truck Enthusiasts Forums
Old 11-07-2006, 09:18 PM
Cam_Man595 Cam_Man595 is offline
Cam_Man595 is starting off with a positive reputation.
My F250 6.0 Diesel did not come with a Lie-O-Meter so I was interested in an aftermarket MPG gauge. Does anyone have any recommendations?
Old 11-07-2006, 10:18 PM
duffman77's Avatar
duffman77 duffman77 is offline
duffman77 is gaining momentum as a positive member of FTE.
I got a scangauge. It doesnt work worth s**t. I bought it for that purpose. For some reason it stops monitoring MPH so it cant calculate MPG. The GPH works good though and I use as an instantaineous indicator. Also monitors coolant temp which I think is useful and is a code reader too.
Old 11-08-2006, 10:50 AM
Vic_Ferrari Vic_Ferrari is offline
Vic_Ferrari is gaining momentum as a positive member of FTE.Vic_Ferrari is gaining momentum as a positive member of FTE.
The only thing that really works is really expensive flow meters.
The NGS scan tool with give you a good camparative idea as to what conditions will give you the best mileage, but that's about it.
Old 11-08-2006, 12:02 PM
Dsl_Burner's Avatar
Dsl_Burner Dsl_Burner is offline
Dsl_Burner is starting off with a positive reputation.
Quote:
Does the scangauge display fuel pressure? I was thinking this would be an easier than plumbing in an actual gauge.
Old 11-08-2006, 02:10 PM
barnbridge's Avatar
barnbridge barnbridge is offline
barnbridge is gaining momentum as a positive member of FTE.
On my scangauge there was a setup screen where I had to choose between a few fuel options, something like gasoline, diesel A and diesel B. I didn't know which diesel setting so I tried one of them and it didn't work. By default the other works great. I don't think there is a readout for fuel pressure.
Old 11-08-2006, 02:23 PM
Quote:
On the NGS there is a PID for "Instant Fuel Economy".
It displays in MPG (yeah, whatever), but is actually very good at finding the mileage sweet spots and troubleshooting low mileage areas while live tuning.
Of course, for the 6.0 you won't be able to live tune (unless you work for Ford MoCo), but you'll still be able to use it as a tool to help tune for improved mileage.
Old 11-08-2006, 11:12 PM
duffman77's Avatar
Quote:
It is Gal per hour. It gets this reading from the OBD2 port so the computer is calculating this somehow. As Vic said it is a good reference tool to determine the efficient operating spots for this engine. The reason mine doesnt work is not because of the fuel side but because it displays 0 MPH about half the time so my average always gets screwed up. Maybe I got a bad scangage or my OBD2 port has a weak signal? Overall it was not a lot of money and I like the ability to monitor my coolant temp in the winter on it. 50C on the scan gage is where my dash gauge starts to move. A lot of people on here will tell you wait for the gauge to move as a warm up indicator. The are wasting time and fuel on that because 50C is plenty warm befor starting to dirve. Check out a cost of a OBD2 code reader, a very handy tool and this does that too, just download the codes off this site and take put them in the truck and you will always know what is wrong with your truck as soon as it happens.
Old 11-09-2006, 09:26 AM
Are you using an NGS+ ?
Old 11-09-2006, 07:37 PM
duffman77's Avatar
I got the Gen I version of this:
http://www.scangauge.com/
Unfortunately for me only about 3 months ago immediately before this came out. At least I paid less.
Old 11-09-2006, 09:11 PM
conger's Avatar
conger conger is offline
conger is gaining momentum as a positive member of FTE.conger is gaining momentum as a positive member of FTE.
I just use the old fashion method for calculating mpg. There's a reason they call it "lie-o-meter"
aftermarket gauges 351M78 1973 - 1979 F-100 & Larger F-Series Trucks 8 01-04-2013 12:30 PM
callibrating mpg gauge? jyarosz 2009 - 2014 F150 4 06-29-2012 11:31 PM
Aftermarket Gauges jgavac 1973 - 1979 F-100 & Larger F-Series Trucks 47 12-14-2011 05:11 PM
aftermarket fuel gauge AJHEATING 1973 - 1979 F-100 & Larger F-Series Trucks 0 09-05-2011 11:56 PM
Aftermarket Transmission Temp Gauge 2000V10USER 1999 to 2016 Super Duty 4 02-15-2010 07:47 PM
Tags
05, 60l, f250, gauge, mpg
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
