Front end specs ????? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-07-2006, 05:47 PM
webkrawler webkrawler is offline
webkrawler is starting off with a positive reputation.
Question Front end specs ?????
I have a '99 250SD 2WD w/7.3/crew/longbed. This truck has had front end damage from some time in it's past where the frame was bent and both front I-beams were also bent. The vehicle had a 4 plus negative camber problem. I have had the frame straightened out and the I-beams replaced by the body shop and when I took it to the front end shop to get the alignment, I still ave a 4 plus negative camber situation. The front end shop here is the best in the area and they are not sure as to exactly what is causing this situation. They are tying to find some specs that they can measure to find the cause rather than just start replacing parts. Is there some type of diagram or spec sheet somewhere that we can access for measurements to diagnose this situation ??
I know that if there is, the guys on this site will know, thanks for any help.
Danny
Ford Truck alignment procedure and tips cantedvalveFord 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 0 02-19-2009 02:35 PM
Is Negative Camber "the Curse of Ford?" Lane Dexter Brakes, Steering, Suspension, Tires, & Wheels 9 01-13-2006 02:02 AM
Adjusting camber on I-beams beertestr Brakes, Steering, Suspension, Tires, & Wheels 2 01-31-2005 07:34 PM
Just got an alignment cjbronco 1978 - 1996 Big Bronco 7 01-17-2005 10:46 PM
Bent I-Beam 66_390 mike 1961 - 1966 F-100 & Larger F-Series Trucks 5 02-14-2001 12:48 PM
Tags
2006, alignment, end, f250, f350, ford, front, specks, specs, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
