97 F150 Heater Core - Ford Truck Enthusiasts Forums
97 F150 Heater Core
Old 11-07-2006, 01:16 AM
fabian1031 fabian1031 is offline
fabian1031 is starting off with a positive reputation.
97 F150 Heater Core
Hi new to the forums, I need help getting info in how to replace the heater core of my 97 f150 I've got the dash loose but I need more detailed info,
Thanks
Old 11-07-2006, 12:25 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
Hello fabian and welcome to FTE.
Do a google search for "dfkelly42 ford" that will get you an e-mail address for 97fordf150, Don Kelly who has excellent instructions that he will happily e-mail to you. Good luck!
Old 11-07-2006, 12:39 PM
Thanks for your help,
will be working on my truck this wendsday
Old 11-07-2006, 01:38 PM
eeyore150 eeyore150 is offline
eeyore150 is starting off with a positive reputation.
I too need to do the heater core on my 98. The manual I have says that the A/C needs to be discharged and disconnected, then the dryer has to be replaced and the system recharged. Is this true?
Old 11-07-2006, 01:47 PM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
Old 11-07-2006, 02:06 PM
You're welcome fabian. Let us know how it turns out for you.
eeyore150, I have not performed this job myself but, I see nothing in the instruction sheet about that and if I remember correctly, this subject has come up before. The AC does not need to be dealt with at all.
Old 04-15-2009, 03:23 PM
tdoe tdoe is offline
tdoe is starting off with a positive reputation.
Thanks for the help! I just got done with mine. Took about 10 hours. I used this post as well as
http://www.ford-trucks.com/forums/78...-pictures.html
I also changed my instrument panel lights that have been out for years!
It sure would have been more difficult if I hadn't found this forum.
P.S. I didn't take my entire dash out!
Heater Core Replacement JasonBrod 1997 - 2003 F150 5 10-04-2012 03:05 PM
97 ranger heater core removal roushboy Ranger & B-Series 2 05-18-2011 02:59 PM
97 f-150: heater blows warm, not hot air. svenska57 1997 - 2003 F150 3 12-30-2010 10:43 PM
'97 powerstroke heater core r&r caljon Cooling, Heating, Ventilation & A/C 2 01-01-2010 09:42 PM
help removing heater core on 1990 F150 Kreedance 1987 - 1996 F150 & Larger F-Series Trucks 5 12-13-2008 01:45 PM
Tags
150, 1997, 97, change, core, f150, heater, instructions, location, picture, pictures, problem, problems, replacement, replacing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
