stock HP rating for 1997 F-350 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-06-2006, 10:58 PM
piperig78 piperig78 is offline
piperig78 is starting off with a positive reputation.
what is the stock ratings for a 1997 F-350 7.3 diesel for Horsepower and torque?
Old 11-06-2006, 11:32 PM
IDMooseMan's Avatar
IDMooseMan IDMooseMan is offline
IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.
Stock HP & Torque for 1997 F-350
I have a 1997 F-350 XLT Crew Cab Long Bed 4x4 with automatic tranny. A sticker on the engine lists 225 HP. I don't remember the RPM this is rated at.
I'm sure someone out here will have the exact numbers you're looking for.
Check under your hood...there should be a label on the engine displaying HP numbers.
Old 11-07-2006, 07:12 PM
ok thanks i'll look under the hood when i get home
Old 11-07-2006, 07:30 PM
79_250RangerLariat 79_250RangerLariat is offline
79_250RangerLariat is gaining momentum as a positive member of FTE.
my 97 says 225 hp @ 3000 rpm
Old 11-07-2006, 08:58 PM
ltfox's Avatar
ltfox ltfox is offline
ltfox is starting off with a positive reputation.
Torque was around 425-450 but dont quote me.
Old 11-08-2006, 08:56 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD DAVID'S97F250HD is offline
DAVID'S97F250HD is starting off with a positive reputation.
Quote:
97 WAS UP NEAR 460 OR 480 lbs of torque, I'll have to check it out when I go home
Old 11-11-2006, 09:32 AM
mcdavidson's Avatar
mcdavidson mcdavidson is offline
mcdavidson is starting off with a positive reputation.
1997 PSD
Factory Ford Horsepower Ratings:
225 H.P.
425 lb-ft torque
Actual:
225 H.P.
480 lb-ft torque
Source: Power Stroke Registry, Vol.1, No.2, Spring 1999, Page 36
Old 11-11-2006, 12:07 PM
ltfox's Avatar
Quote:
How bout that David....Were both right!!!! LOL
stock transmission cooler ratings quincyj34 1987 - 1996 F150 & Larger F-Series Trucks 3 05-01-2014 02:32 PM
Front clip 1997fordf350 1987 - 1996 F150 & Larger F-Series Trucks 3 06-03-2013 08:19 PM
Speaker size 1997fordf350 1987 - 1996 F150 & Larger F-Series Trucks 6 08-01-2012 11:31 AM
97 f450 tow rating??? charlessocccer 1994.5 - 1997 7.3L Power Stroke Diesel 3 03-11-2010 02:51 PM
429 hp/torque ratings 006f350diesel Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 07-15-2006 02:02 AM
Tags
1996, 1997, 73, 73l, 96, diesel, f250, f350, horsepower, hp, powerstroke, rating, ratings, stock, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
