Wide White Wall needed
As a visual prop only, I need (1) wide white wall tire. It is to be used as a pretend spare tire. The rim I have is a 15", so I need a 15" tire with virtually any width. It does not need to hold air as I can put a tube in it. I do need the white wall to be in good shape and to be anywhere from 2" to 3" wide. If you have a wide white wall just sitting around in the way, let me know how much you want for it. Thanks, Jag
on
I know JC Whitney used to sell a whitewall paint made for making your own wide whites. We bought some for the LaSalle when I was kid. Worked pretty well, lasted for years.
If I have any wide whites left around here, they'd be pretty old and cracked, probably mounted on a wire wheel and wouldn't likely hold up to being dismounted and remounted again. But I'll look...
That's good news Larry. I did not have any luck at Pleasanton. Is at least one of them in fairly good shape? I'll take all four of them just to keep them from being thrown out. When would be a good time to drive down and get them? If you PM me with your phone number, I'll call you and get directions. Thanks, Jag
Jag Red 54
21
03-02-2014 06:19 PM
ZCarr
07-17-2013 05:37 PM
Wayne Waldrep
18
09-13-2012 02:39 PM
JohnT
06-03-2007 01:03 PM
