engine swap rad hose problem
11-05-2006, 08:43 PM
on
Ok finally got a good motor for my 78 4x4. My problem is rad hoses. The truck originally came with a 400 which was then swapped to a 351 cleveland. I pulled the cleveland and installed a 351 windsor. Does anyone know if the rad hoses from a 302 engine will fit since these trucks never came with the larger 351 windsor. The rad is original. I don't know if the rads were the same size between the 302 and the 400. If they were then it should be a simple process. Any input is greatly appreciated.
11-06-2006, 01:24 AM
I can't tell you if the 302 and 400 radiators are the same,but i can tell you the 302 radiator hose will work for the 351w.
11-06-2006, 11:34 AM
on
I used an upper rad hose for a 351W from a van. Has loads of clearance for non-existent v-belts.
Don't know about your truck, but on mine, the 351M rad was 4" wider than the original 302 rad.
11-06-2006, 05:53 PM
on
the radiator for the 400 will be if i remember right a 3 core while the radiator for the 302 is a 2 core so it will be a bit larger ... the diff you will run into there will be that it will take longer for you coolant to heat up to opperating temps
11-06-2006, 06:06 PM
on
or scratch that it came with a 4 core to cool that series of engine i dun kno where i pulled 3 core outta
11-12-2006, 06:33 AM
on
The stock bottom rad hose for a 302 will work just fine. u will probably have to get a 302 with a/c top rad hose as the bung on the rad top is bigger diameter on the larger rad. i used the stock 302 top rad hose on my 351 with a 460 rad. but it is a real tight fit.
11-12-2006, 07:15 AM
Old Timer is right, I used a 78 302 with ac hose on my 78 with 351W.
olblue77
05-31-2016 04:43 AM
Eh1992xlt
02-04-2016 10:34 AM
olblue77
21
01-14-2013 10:35 PM
bigdogger
01-27-2005 03:24 AM
FordRacing2
15
08-12-2003 09:39 PM
