best exhaust option for my 5.4 - Ford Truck Enthusiasts Forums
Old 11-05-2006, 06:26 PM
Spectre 023's Avatar
Spectre 023 Spectre 023 is offline
Spectre 023 is starting off with a positive reputation.
hey guys. ive got an f250 5.4 sd.
im planning on doing some exhaust work, but i want to know what will get me the best results.
those cast headers look really restrictive, as does the passenger side pipe where it merges before the cat.
anyone have any suggestions/results to offer?
any help would be greatly appreciated.
Old 11-05-2006, 06:34 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
I manifolds are actually not too bad.
Your biggest restriction is in the Y-pipe. Read here for more info on that http://www.ford-trucks.com/forums/53...n-a-5-4-a.html
I've always had good luck With Flowmaster myself.
Old 11-05-2006, 08:14 PM
flowmaster exhaust system or flowmaster y pipe?
anyone know where i can get a good y pipe..ive been looking, but cant seem to find one
Old 11-06-2006, 03:18 PM
LxMan1's Avatar
There is a guy on ebay that sells them I think. Flowmaster cat-back system.
Pehaps you can contact this ebay seller about a y-pipe http://cgi.ebay.com/ebaymotors/00-04...32711240QQrdZ1
Old 11-06-2006, 06:03 PM
will teh truck still pass inspection though?
i need to drive the truck on a daily basis...
Old 11-07-2006, 05:41 PM
lariat97's Avatar
lariat97 lariat97 is offline
lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.
As long as you don't remove the cats you will pass inspection. Cat back systems are 50 state legal.
Old 11-07-2006, 06:14 PM
oh, ok cool
also, the y pipe in that link claims to give 33 hp...which i dont nesessarily believe, but aside from that, does anyone know where in rpm range that is? i want to keep my low end torque, not sacrifice it for high end power...
Old 11-07-2006, 07:46 PM
kspilkinton's Avatar
kspilkinton kspilkinton is offline
kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.
The 'y' pipe may give you 33 hp, but at 4500 rpm... a fact that doesn't always come to light. You are wise not to give in on a claim.
Here's the deal: Torque is a product of flow velocity, so the smaller the tube the faster the flow, to a point. However, horse power is reliant on the flow volume, so the bigger the tube the more horse power, to an extent. This means both sides of, and includes, the cylinder head.
The factory pipe is necked down to around 2 1/4". This would throw up a flag, right? You'd lose that diameter by going with this after market pipe, right? Not necessarily, the factory cats also proved an internal 2 1/4" diameter. You're keeping those to pass inspection. This will help you keep the velocity necessary to keep your torque down low. Adding the new 'y' will do nothing for that, but should allow for a higher flow at higher rpms... giving you hp, but most likely at 4500 rpm.
Without replacing both the intake side, heads, exhaust, and a doing a reprogram, you might be hard pressed to see or feel a performance gain. People claim one thing, but without the dyno tests to prove it... I'll rely on engineering and physics.
-Kerry
Old 11-07-2006, 08:00 PM
so in other words....your saying that its not worth it?
i want the most out of my truck for a modest price.
the truck was my father's before mine.
im 18, so its obvious that i dont have a lot of money.
im looking at a gibson swept side cat back exhaust, which show the best gains and sound characteristics for me.
here is a picture of my truck, it was completely stock with grey factory running boards, so you can tell a lot has changed. ive done all that on my own, with a job on top of after school practice. now that ive done that im looking to upgrade performance, i just finished installing a k&n fipk and have the 04 headlights on order(excited about that). im looking into hypertech tuning, which will come in december, but for right now im looking at my exhaust options.
Old 11-07-2006, 08:21 PM
Go online, read about how to get what you want from the truck... yeah, it requires more studying - just what you want to hear. Learning about how to build it the way you want it now will prevent you from wasting money on stuff that won't get you where you want to be.
If you can justify the pipe for a leter project, say a supercharger, then it's a good buy - if not, then save your money for an exhaust that can provide you the numbers you want to see.
The tuners are great for bringing out what performance there is left in the stock to mildly modified drivetrain. However, go with a tuner that has some adaptability if you're going ot drop that much money... SCT, Diablosport, even Edge. Hypertech never really caught my eye as they seemed to lack some bells and whistles for future improvement.
The unfortunate part is that many companies sell performance parts that only add on at higher rpms... a point that they don't readily publish. Glad to see you have caught on to that. Also don't immediately go for the "popular" fix... for instance if someone suggests a drivetrain mod and it sounds cool, bounce it off a perfromance engine builder or an engineer. They'll tell you why it either works or doesn't.
-Kerry
Old 11-08-2006, 10:12 PM
thanks for the help.
i think im going to go with a gibson swept side exhaust and not worry about the y.
i figure its there for a reason and im just not going to mess with it, i dont want to inadvertenly lose some of my low end torque.
also, is there a real difference between alumanized or stainless steel?
Old 11-08-2006, 10:36 PM
The only difference is longevity... stainless doesn't rust except the welds, aluminized will rust where the aluminum has been removed, welds first and any damage spots.
-Kerry
Old 11-08-2006, 10:41 PM
what difference in life would you expect?
is stainless worth the extra 150?
Old 11-09-2006, 07:17 PM
LxMan1's Avatar
Stainless will usually last the life of the truck and is usually guaranteed to do so.
Old 11-09-2006, 09:52 PM
I would say the stainless is worth it, if this is the system you want for the next 10+ years. Problem is your goal and tastes may change... I opt for the alumanized just for this reason. I can always go after a custom stainless set-up if the manufacturer stops making the kit later on in 5 years.
-Kerry
Best drop in air filter for MPG / Performance Pastor Scott 1999 to 2016 Super Duty 2 11-02-2016 10:27 PM
5 Star 5.4 tunner Projectlittleredf250 1999 to 2016 Super Duty 31 04-06-2016 12:44 PM
Best Chip/Programmer FatDutchMn Computer Chips & Tuners 8 05-04-2011 09:06 AM
5.4 Towing Performance gregghealy 2004 - 2008 F150 150 10-26-2007 09:27 AM
Coil Pack Question 344PV 1997-2006 Expedition & Navigator 6 10-18-2007 06:56 PM
Tags
2001, 54, back, cat, engine, exhaust, f150, f250, f350, ford, hp, money, side, torque, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
