Hanging Brake Pedals in a 48-52 - Ford Truck Enthusiasts Forums
Old 09-20-2002, 08:47 AM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
I'd like to convert from a floor mounted master cylinder to one I can mount on the firewall in my 48 F3 pickup. I'm sure others have done this. Is there room in the engine compartment for a small power brake booster and dual master cylinder using a small block engine? What seems to work best as far as a pedal assembly? I'd prefer to stay away from kits and use a salvage yard pedal assembly if possible. Is reinforcing necessary for the firewall? Is there some reference point I can use on the firewall to determine where to locate the master cylinder? I'll be using a GM tilt column and probably 67-72 Ford Master cylinder. Is there a particular small booster that fits this cylinder that would take up less space. I've heard that Fairmont boosters might work. Any comments appreciated.
Old 09-20-2002, 09:59 AM
Huntsman's Avatar
Huntsman Huntsman is offline
Huntsman is starting off with a positive reputation.
Vern, There is a good tech article by John Niolon at this link. You may have already read it. I realize you have a 48 model truck but some of it would probably still apply. http://www.ford-trucks.com/articles/pedals/index.html
Old 09-20-2002, 05:15 PM
fatfenders's Avatar
fatfenders fatfenders is offline
fatfenders has a good reputation on FTE.fatfenders has a good reputation on FTE.fatfenders has a good reputation on FTE.
Vern
Find a hanging pedal and booster combination that works for your truck. Then buy a master cylinder (MC) to fit it. MCs are very cheap at the discount parts houses. Don't force yourself to build the truck around a used MC you happen to have laying around. 79-93 Mustang is another option for you. I use a mid seventies Ford van in my 53. It works OK but the booster could certainly be smaller. I would do the Mustang if I had it to do again.
'fenders
Old 09-20-2002, 05:56 PM
Tom,
That's a great article by John. I think my 48 will be much the same as his 53. Thanks for the tip. I do plan to use a new Master cylinder...probably a Mustang.
Old 09-22-2002, 08:03 PM
41Clay's Avatar
41Clay 41Clay is offline
41Clay is starting off with a positive reputation.
I used a petal assembly out of an Aerostar bacause it is has a cast aluminuim mount that can bolt right to the firewall without welding and and has a large area for support. I didn't rienforce my firewall but a little would be nice. It also fits with a 390 under the hood, I positioned mine as close to the engine as possible but there's plenty of room for it to move further out.
Old 09-22-2002, 11:41 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
52 F1 firewall mounted master cylinder advice PRG3216 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 06-28-2015 10:22 PM
N-600 Brake Booster. cmongft Large Truck 4 10-19-2014 09:48 PM
Converting F250 to manual brakes Rusty_Old_F250 1973 - 1979 F-100 & Larger F-Series Trucks 0 05-22-2014 01:34 AM
Acceptable angle of master cylinder push rod mgargiullo 1957 - 1960 F100 & Larger F-Series Trucks 2 04-13-2014 10:19 AM
brake booster question 77F150Jason 1973 - 1979 F-100 & Larger F-Series Trucks 3 10-01-2012 02:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
