Which Motor - Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
View Poll Results: Which Motor Should I put in my 71
302 2 14.29%
351W 3 21.43%
390 4 28.57%
460 5 35.71%
Voters: 14. You may not vote on this poll
Which Motor
Old 11-04-2006, 07:58 PM
tanman722001 tanman722001 is offline
tanman722001 is new and has a neutral reputation at this point.
Which Motor
Which motor should I rebuild for my 71.Right now it has the 390 in it.Thinking of keeping the 390 and rebuild it.But would like you guy opinon on which motor you guy would chioce
Old 11-05-2006, 10:03 AM
SuperSnake's Avatar
SuperSnake SuperSnake is offline
SuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to beholdSuperSnake is a splendid one to behold
Go with a 460 gobs of torque
Old 11-05-2006, 11:42 AM
79 Trailer Special's Avatar
79 Trailer Special 79 Trailer Special is offline
79 Trailer Special is starting off with a positive reputation.
My opinon???? not to often anyone asks Well just what are your plans for the truck and how are you going to use it? If its going to be a driver and you want to have some fun with it I would lean towards the Windsor. Lots of performance parts available to build it into whatever power range you want. Less weight in the nose so it will handle better than if you had all the weight of a big block up front. If built right you could still get halfway decent gas mileage (if you can even use that term on these trucks) outa her.
Dont get me wrong, I love the 385 series and even run one in my truck but for everyday use a windsor can be more than enough.
Old 11-05-2006, 11:48 AM
ford4ever4wheeler's Avatar
ford4ever4wheeler ford4ever4wheeler is offline
ford4ever4wheeler is starting off with a positive reputation.
460 for sure
Old 11-05-2006, 11:50 AM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
460 would make an awsome ride
Old 11-05-2006, 05:54 PM
MAKO314's Avatar
MAKO314 MAKO314 is offline
MAKO314 has a good reputation on FTE.MAKO314 has a good reputation on FTE.
I would say the 444E diesel now thats a real engine, gas is for little girls
Old 11-06-2006, 08:01 PM
ncfirefighter46's Avatar
ncfirefighter46 ncfirefighter46 is offline
ncfirefighter46 is starting off with a positive reputation.
I will agree DIESEL YAHOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!
Old 11-06-2006, 08:27 PM
No Diesel.Not in a half ton two wheel drive pickup.That going to be a hotrod
Old 11-06-2006, 08:35 PM
I guess i might as well keep the 390 and build it.Like Bore .30 put flat top piston.Shave the heads and put bigger valve in them.Put a good cam in it with a little hit to it.And headers and a bigger carb like a 750.Maybe more still thinking about what else.
Old 11-06-2006, 08:52 PM
SuperSnake's Avatar
Tony, Drop in the 460 so you can peel the paint off the ricers.
Old 11-06-2006, 08:56 PM
im sure when I get the 390 done it will do it too.
Old 11-06-2006, 09:04 PM
SuperSnake's Avatar
either way ci can't be beat.
Old 11-06-2006, 09:22 PM
MAKO314's Avatar
OK Cliff my 444E against a 460, bout it big boy
Old 11-06-2006, 09:28 PM
SuperSnake's Avatar
Quote:
Sure after you rebuild it with the parts I want.
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
