Hello everyone. Iam looking to get rid of the unsightly plug for the block heater. It just looks like a cheap way of plugging in my investment. I would like to install a 3 prong male ac plug with a weather tight metal cover in the front bumper somewhere. My only delimea at this point is where to find the
plug with cover. Any help and pics. would be appreciated. Thanks.
Here I am... check out my gallery for pictures of a clean install of the Marinco AC plug adapter.
Here is what you will need...
1) Marinco AC plug - Model #BB150
2) Length of power cord (extra heavy duty gauge for wattage requirements).
3) Female plug (connects into stock plug).
4) Roll of black electrical tape (some are made for cold weather - less brittle).
5) Drill & hole cutter - to drill/cut large circle for Marinco plug
thank you beachbumcook, for the great write up on the marinco ac plug. Your gallery pics. show your install to be very clean. I am looking forward to performing mod before snow flies. Thanks again to everyone all replies.
I just put one in my truck on Sunday. Kinda hated to drill a hole in a perfectly good bumper, but did it and it looks great.
I bought my Marinco at a boat shop. I think it was about 30 bucks. I didn't use any extra wire. I just identified the wires already in the plug, cut the plug off, Soldered the ends of the stranded wires to make them rigid and installed the wire into the Marinco male receptacle. It came with a nice rubber boot to cover the wires and the rear of the unit. A short piece of heat shrink tubing sealed the wire/boot interface nicely.
It looks 100 times better than the end of the block heater plug hanging out through the grill.
__________________
97 250 PSD Ex Cab Sd 4X4 ZF5 135k
6637 in, 4" stainless ex
cat-less
Pyro & Boost
15.6k (tx c00n!)
Fumoto drain
HPX
Marinco block heater tap
08 Diff cover
R.P. trans fluids
203 deg t-stat
Line-X
SiriusXM music & talk
Hula HP
EBPV brake
"I tried being reasonable. I didn't like it."
So you must have left the plug you installed on the passenger side of the truck? The reason for the extra cord I added was to preserve the stock plug and wire hook-up and to extend the actual hook-up to the drivers side to make it easier for me to plug-in and dis-connect when in my garage... and to lay the extension cord over my mirror ro remind me to un-hook it!!
Mine is a '97 and the block heater cable exits the engine compartment from the drivers side of the grill. The cord was plenty long enough to move it even further towards the drivers side of the bumper. Actually, I might have preferred to have it come out of the passenger side of the vehicle as that is where the closest outlet is where I park.
Had I been super-ambitious I could have split the wire and put 2 in so I could plug it in from either side no matter where I parked it!
I don't use it all that often here in SE PA, but we do get pretty chilly for several weeks at a time in the winter and warming the block in the morning makes me feel better about the engine getting to operating temp faster on my relatively short drive to work.
Aside from the aesthetic improvement, my other complaint about the heater cord was that the rubber cap would invariably fill with snow or ice when it was removed so that the heater could be connected to power. Then when I'd disconnect the power, I couldn't put the protective cap back over the plug.
This should stop that problem as well.
__________________
cat-less
Pyro & Boost
15.6k (tx c00n!)
Fumoto drain
HPX
08 Diff cover
R.P. trans fluids
203 deg t-stat
Line-X
Hula HP
EBPV brake
you could go for a company called autoeject they do the self ejecting plugs for firetrucks and ambulances ive seen them converted onto explores and whatnot
here is a better idea. I have had this thing on my truck for 3 years and it works great. http://www.arcticleash.com/
__________________
Max W
06 F-350 4X4 6.0 PSD NORTH POLE, ALASKA
Mobil-1 5-40 turbo diesel truck oil from day #1
98 gallon transfer flow tank
Leer topper insulated
MBRP SS409 turbo back Off-Road duel exhaust-CAT IS GONE
AstroStart 2-way Auto start
Go Rhino pushbar/brushguard,4-9" Lite-Force moose lites
You got mail
kawa
__________________ 1997 Red F250 HD CC 2X4 E4OD
6637, 203* Stat HPX,1.0 Turbo Piller: Boost, Trany Temp, EGT. Top of Dash: Water Temp,
Eng Oil Temp, Fuel Press. 71#
SD Fuel Heater, 140v IDM
CCV w/filter
Tran Cooler, Coolant Filter
Exhaust Brake, 5th Wheel
Cadillac Battery Water
Detroit Locker, Fin Diff. Cover The Cure
