7.3 High Pressure Oil Line Problem? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-04-2006, 06:20 PM
John Rowe John Rowe is offline
John Rowe is starting off with a positive reputation.
I am about to take a trip with my 2000 F350 with 88,000 miles. I've done all the regular things to prepare for the drive (new oil, filters, coolant, etc), which also includes putting a new cam sensor in about 1000 miles ago (I always carry an extra!).
A friend of mine suggested having the "high pressure oil line seal" replaced. He said that the 7.3 has a problem with the seal going out and when it does, the engine losses all the oil in a matter of seconds.
Anyone heard about this problem? Any other suggestions?
Thanks, John
Old 11-04-2006, 06:36 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
There are o-rings that seal the connection between the port coming out of the High Pressure Pump, and the lines running to the oil galleries in the cylinder head. It's a good idea to keep a set in your toolbox, or in this case, with you in your glove box. They can go out at random. You could go for the life of the engine with no problems, or only a few ten thousand miles. Not many people have these leak from what i see. I wouldn't replace it if it isn't broke, but you can keep the seals and tools with you so you will be ready for it if it comes. www.puredieselpower.com has the seal kit.
Old 11-05-2006, 07:29 AM
Sounds like I'll leave good enough alone! Thanks for the advice.
John
Slipping Clutch flattie39 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 05-16-2015 08:46 PM
Smoking at Idle Sweater61 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 12-25-2014 12:47 AM
As the temp rises, the no start hot issue gets worse. sportsdad 1999 - 2003 7.3L Power Stroke Diesel 13 06-08-2014 06:06 AM
Posting from John Wood's WiFi gabeyd Excursion - King of SUVs 10 10-26-2013 05:01 PM
Gauges stopped working 1990 F350 drcougar 1987 - 1996 F150 & Larger F-Series Trucks 1 10-07-2009 07:59 PM
Tags
73, f250, ford, high, hose, line, lines, oil, ooil, pressure, problem
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
