1994 Ford Ranger Heater problems - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-04-2006, 04:26 PM
flo21i99 flo21i99 is offline
flo21i99 is starting off with a positive reputation.
1994 Ford Ranger 3.0L V6 4x2 60,000 miles, manual transmission. Heater is not working, blowing cool air. Replaced heater core, thermostat, gasket, coolant and heater hoses. Question is what can be the possible problem if not any of those and if, let's just say for example, I connected the heater hoses (the ones that attach to the heater core) incorrectly does that really matter? Anyway what is the correct way for the heater hoses to be connected? Is it the left outlet (looking at the engine from the front of the vehicle) of the heater core to the water pump connector or is it to the thermostat connector. Which one goes where? Like I said before I don't know if it really makes a difference but if it does can someone please give me some guidance? And no, I am not really a mechanical type guy. Thanks for your help in advance
Luis
P.S. I have the Haynes repair manual but it's not really much help.
Old 11-04-2006, 05:03 PM
john112deere's Avatar
john112deere john112deere is offline
john112deere is gaining momentum as a positive member of FTE.
I'd hazard a guess that it could be the blend door, but a couple quick checks, first.
Does the temp gauge come up like it used to when the heat worked? Do both hoses going into the heater core get hot?
Old 11-04-2006, 09:12 PM
Tiggie's Avatar
Tiggie Tiggie is offline
Tiggie is starting off with a positive reputation.
Sounds like you've covered the normal bases, could be the blend door. Your will have a different design than the newer ones, though.
Old 11-05-2006, 01:54 PM
John112deere,
Funny you ask that because the temp guage did not come up like it used to. As a matter of fact it barely came up at all. The heater hoses were't too hot. Not sure how hot they should get but lets just say I can grab the heater hoses and leave my hand on it without fear of getting burned. They were warm at best. Any ideas of what it could be?
Tiggie,
Where is the blend door and what should I llok for if there is a problem?
Thank you for your responses.
Luis
Old 11-05-2006, 02:07 PM
BearMan54 BearMan54 is offline
BearMan54 is starting off with a positive reputation.
Post
Well flo21i99, that's the same way my truck acted..... Temp gauge barely moved, only warm heat, hoses not hot...... But I changed my thermostat with a Motorcraft unit & it fixed all my problems...... My gauge is mid way up and nice hot heat.....! Just maybe you got a bad thermostat...... I've seen it happen before.........
Oh yea, my old thermostat was stuck about half way open, so my engine would never get up to operating temp.....
Hope this helps.....
Old 11-05-2006, 02:42 PM
BearMan54,
A new thermostat huh? Before I do that does anyone know if having the heater hoses connected incorrectly(backward) might be a problem. If someone believes that might be the cause please let me know the proper way they should be connected so I can check out my vehicle.
Thanks BearMan54. Will see about the heater hose connection first before i try changing the thermostat.....again.
Thanks,
Luis
Old 11-05-2006, 03:06 PM
Tiggie's Avatar
I don't really see any reason for the hoses being connected backwards to affect the heat.
Since your temp gauge is reading low and heater hoses aren't getting hot, it definitly sounds like a thermostat issue.
Heater Core Hoses: Inlet x Outlet/Return celsoglima Ranger & B-Series 7 12-16-2016 10:06 AM
2001 ford ranger 2.3l heater core jrg24 Ranger & B-Series 3 01-12-2014 08:06 AM
heater hose connection 1981Ranger 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 07-07-2013 08:10 AM
Heater core quick connect part #s? brokenjack Aerostar 8 08-09-2012 11:01 PM
Heater Hose/COPS and Flushing questions 5.4 2000 expy knix Expedition & Navigator 4 12-16-2009 10:11 AM
Tags
1994, 1994ford, ford, heat, problems, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
