Code P0301 (misfire) troubleshooting - Ford Truck Enthusiasts Forums
Old 11-03-2006, 08:47 PM
CR125Honda CR125Honda is offline
CR125Honda is starting off with a positive reputation.
Just bought a 1997 EB Expedition, 5.4 engine, 148000 miles..
I'm getting a code P0301 (cylinder 1 misfire detected).
The engine idles a bit rough and lacks full power.
Can I assume it's either a bad spark plug, bad #1 coil, or clogged #1 fuel injector?
To start the troubleshooting, I was going to move the #1 coil to the #2 position and see if the fault follows (unless someone knows how I can check the coil with a VOM, I'd need to know which pins to touch and the expected values). I've read the other post about the bad boot info. Will check that also.
If it didn't follow, next I would change the #1 spark plug.
If that didn't cure the problem (code), next would be to check the fuel injector. Not really sure how to check them.
Can someone also verify the #1 cylinder is the front/right cylinder (or closest to me and to the left as I stand in front of the truck)? I bought the Ford service manual on CD but couldn't find the cylinder order anywhere.
Am I one the right track? Any tips or advise on the subject would be appreciated.
I'm currently replacing the upper and lower ball joints and will be tracing down a bearing noise that occurs while in motion. Hopefully it will be in the right wheel hub (I have the left off now and it feels fine). Really hope it's not coming from the front differential.
Just want to be prepped to do the engine after I finish the suspension work.
Ken
Old 11-04-2006, 09:54 PM
JH6 JH6 is offline
JH6 is new and has a neutral reputation at this point.
replace the spark plugs. If that doesn't do it, then you need a coil as well. Motorcraft only.
Old 11-05-2006, 12:12 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
4 8
3 7
2 6
1 5
Front
Replace the plugs with Motorcraft or Autolite double platinums. Clean the MAF and change the PCV valve, then go from there.
Old 11-15-2006, 01:45 PM
murray44 murray44 is offline
murray44 is starting off with a positive reputation.
Cool missing in overdrive
I have a 99 f250 4.6 4x4 with 48,000 mile ,it starts missing when going up little hills at 60 to 65,Turn off OD run fine
Old 11-15-2006, 04:21 PM
LxMan1's Avatar
Could be moisture in a plug pocket ot a bad coil boot, or even a dity MAF.
Old 11-15-2006, 06:00 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Ken, do what you were going to do first. The easiest thing to do should always be the first step Sometimes.
It'll take you a few minutes to swap them. When you pull that #1 COP make sure the boot is dry and no crud all over it. You might just have a wet hole ...
If you already have a problem, and it's obvious what cylinder it's in, there's no reason to start swapping all the plugs at once without making absolutely sure what the misfire is. You could create more problems than what you had to begin with.
As to the bearing noise, have fun Is the right one loose at all?
Old 11-22-2006, 10:34 PM
mudrnnr79's Avatar
mudrnnr79 mudrnnr79 is offline
mudrnnr79 is starting off with a positive reputation.
I would have to agree with JH6 replace plugs first when was the last time they were changed?
Old 12-31-2006, 06:22 PM
(apologize for the double post, I thought this was the better thread to put this info in)
Update....
Swapped #1 and#2.. Problem moved to #1. Purchased an authentic motorcraft DG508 coil from dealer (lots of fake "OEM or "OE" Motorcraft coils being sold online, see below). Anyway, that cleared that problem.
Then... Test drove and got a pending p0303 code. Cleared that code then test drove again to verify. This time got an MIL (check engine light). This time it pulled code p0304. Errr...
Now the plan is to find six new authentic coils at a reasonable price (one was replaced last year before I purchased the vehicle). If anyone knows where I can find them at a discount, please let me know.
I purchased a set of the knockoff's about a month ago off eBay. Price was right at $130 for eight with platinum plugs! Returned them.. Wrong plugs (though the guy guaranteed me they would work, he didn't confirm that he would pay for the overhaul if they were too hot or smacked the top of the pistion) and I also didn't like the way the connector hook up on the coil was made. The authenic motorcraft coils have a little step inside the female portion of the connector that allows the rubber in the connector to make a good seal. The knockoff's do not have this.
Glad I have another car to drive in the mean time...
Old 01-02-2007, 01:09 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
Quote:
Update....
I can sell you some if you like.
Ed
Old 01-09-2007, 11:38 AM
Update..
Went to the local junk yard and picked up a few OEM coils. Replaced #3 and #4.
Test drove.. No pending codes or MIL light.
Good power, averaging 13.7 MPG on the short amount of driving I've done to date.
Engine repair involved changing all spark plugs and three COP's (#2,#3, & #4). Removing left exhast manifold and replacing rear most manifold stud. Replacing the two long studs in that manifold that joint the "Y" pipe.
Steering and suspension is like new after replacing upper control arm (with bushings and ball joint) and lower ball joint.
What I thought was a bearing noise turned out to be something else.
There are a few heat shields that follow the exhaust. I found that one of them was rubbing the front driveshaft, making what seemed to me to be a low picthed grinding bearing noise at low speed. Bent it back in place. Noise gone.
The rest should be relatively easy to complete - oil line to remote oil filter has small leak, shift lever on column a little stiff to move, left signal mirror needs replacing, a little touch-up paint, etc..
Thanks for eveyones help, very much appreciated.
All is well for now.
Ken
'05 Expedition - Cylinder 1 misfire super_steve85 1997-2006 Expedition & Navigator 22 07-03-2015 10:50 AM
Misfire Cylinder 1 7.5l P0301 JonEB 1987 - 1996 F150 & Larger F-Series Trucks 7 10-30-2014 11:39 AM
code P0301 jfp3205 2004 - 2008 F150 1 10-10-2013 08:36 AM
It runs awful when it rains 88 Bronco Ranger & B-Series 21 12-22-2009 12:46 PM
2000 Ranger 3.0L misfire Cylinder #1 AND #5 majoiner 3.0L V6 4 06-16-2008 08:51 AM
Tags
03, 54, bad, code, coil, expedition, f150, f250, fire, ford, mis, misfire, p0301, troubleshooting, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
