Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-03-2006, 12:19 AM
wesh wesh is offline
Garage is empty, add now
wesh is starting off with a positive reputation.
propane conversion
i have a 75 ford f-250. just wondering what it would take to convert it to propane. Ive also heard about a propane/gas combo and that u can run both depending on if you need more power or not. what would it roughly cost and what kind of power lose might be expected. and what kinds of modifications need to be made.
  #2 (permalink)
Old 11-03-2006, 01:25 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. Check the links at the bottom, and the menu bar at the top, of the page for more information and resources. Have fun!
__________________
"Beam me up Scotty. There's no intelligent life down here..."
  #3 (permalink)
Old 11-04-2006, 12:30 AM
o7dgm o7dgm is offline
o7dgm is starting off with a positive reputation.
try www.propaneguy.com and www.autopropane..com they have a lot of info.
  #4 (permalink)
Old 11-05-2006, 04:23 AM
darrin1999 darrin1999 is offline
darrin1999 is starting off with a positive reputation.
it all depends on how many modifications you want to do what it takes... the absolute minimum is a mixer, evaporator, lockoff, coolant splitters for the evaporator, vapor line, service line, and a tank- can be had at propaneguy.com for about 600 dollars. you should get your distributor recurved and advance the timing a bit- encouraged but not absolutely necessary. if you dont modify the engine to run propane exclusively by increasing compression youll lose somewhere around 10% power and mileage. if you make it a dedicated propane engine then you can actually gain power and get about the same mileage if not slightly improved
Tags
1978, 2006, 250, conversion, convert, coversion, f250, fargo, ford, gas, propane, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
