EFI - Vacuum Lines - 1990 302 - Ford Truck Enthusiasts Forums
Old 11-03-2006, 12:15 AM
re_fill re_fill is offline
re_fill is starting off with a positive reputation.
New post, same problem. I posted this some weeks ago where I changed my plugs, wires, and filters, then miserably failed an air-care test. Well as I reposted, I had been a little careless when installing the plugs and cracked the porcelain insulator on 1 (or more) plugs. I since replaced ALL the NGK's with Bosch plugs (I blamed it on the NGK's, but that was wrong). So now it runs well, but won't idle. It "hunts" if you know what I mean. If I come to a stop, it will stall unless I put it in neutral. In neutral it will stall if I turn the steering wheel. If I put ANY load on the engine in neutral, it will stall. So I figure that when I changed the plugs I have knocked or broken or undone a vacuum hose or some other EFI mechanism. If I hold the pedal at 800-900 RPM, no problems, but that is wrong. I can't find or see any problems.
Anybody have or know of a schematic of the EFI system and vacuum hose routing to troubleshoot this goof-up?
As always, thanks in advance.
phil
Last edited by re_fill; 11-03-2006 at 12:25 AM. Reason: my Pinto de-Tomaso got rear-ended and DIDN'T blow up, the Firenza did
Old 11-03-2006, 06:47 PM
dwoodler's Avatar
dwoodler dwoodler is offline
dwoodler is starting off with a positive reputation.
It should be on a sticker under the hood. Either on the air intake box or the along the front somewhere.
Old 11-12-2006, 10:35 PM
carriljc carriljc is offline
carriljc is starting off with a positive reputation.
I replaced all the hard plastic vacuum lines...
with rubber tubing a couple of years ago. It eliminated a bunch of problems, and it's run a lot better ever since.
Old 11-13-2006, 06:46 AM
b4hntn b4hntn is offline
b4hntn is gaining momentum as a positive member of FTE.b4hntn is gaining momentum as a positive member of FTE.
My hose diagram is hard to read where they put it. A digital camera helps a lot. If you do not have one a MityVac vacuum tester is about $30 then you will know all the vacuum systems are correct. Then you did not mention pulling codes?
Old 11-13-2006, 06:59 AM
buggzz buggzz is offline
buggzz is starting off with a positive reputation.
Check and then re-check your spark plug wires. From what you have said (changing spark plugs twice and all) I'd bet you connected the spark plug wires wrong and messed up your firing order.
What was the results of the emissions check? High hydrocarbons, high NOX, etc?
It could be a vacuum line, check them as well.
Ask your tranny shop if they removed the upper intake in order to lift the motor to change the rear main seal. If so, they probably created an intake leak.
Above all, Stop just replacing parts in the hopes of fixing it. diagnose the problem, test the suspect part, and then replace it if necessary.
Old 12-27-2006, 08:14 AM
phildntn phildntn is offline
phildntn is starting off with a positive reputation.
vac lines
Try looking at the red vac lines on top of the motor they are made out of a hard composite material and can crack with out it being visable my truck would stall at every light once I changed mine on my 93 bronco no problem it has run fine since.
Old 12-28-2006, 04:46 PM
It wasn't the vacuum line(s) afterall
Thanks for the insight, but as it turns out, my fuel pressure regulator AND Oxygen senser weren't working. The engine was constantly flooding. All is well now.
NGK 372 Experience? 2008+ 5.4 3V mike460 2009 - 2014 F150 0 04-15-2014 10:53 AM
2009 5.4L Replacement Spark Plugs NewXer 2009 - 2014 F150 3 02-27-2014 07:51 AM
1988 ford f250 problems redneck201383 1987 - 1996 F150 & Larger F-Series Trucks 8 11-20-2013 07:17 PM
Platinum plugs for an old truck? 1992FordF150Custom 1987 - 1996 F150 & Larger F-Series Trucks 28 11-26-2012 10:18 PM
92 F-150 302 EFI spark plug issue? Jrock909 1987 - 1996 F150 & Larger F-Series Trucks 0 11-23-2004 10:44 AM
Tags
1990, 302, 460, efi, f150, high, hose, hydrocarbons, idle, lines, plug, routing, routing302ford, schematic, vacuum, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
